I have a cast aluminum transmission part to weld. Any precautions to make on oiled cast aluminum ???
Reply:Originally Posted by rahtreelimbsI have a cast aluminum transmission part to weld. Any precautions to make on oiled cast aluminum ???
Reply:I have a top form a GMC manual transmission. The shifter is in a flat housing that is held to the transmisiion by 4 bolts. One of the ears broke off. The mounting hole is still intact. The break is past the hole by roughly 1/2". The part in question has some transmission oil (maybe ATF) on it. If you guys need more info let me know!!!
Reply:Clean,weld. Clean, weld. Clean, weld. Clean, weld. In this order keep repeating til desired results are achieved.
Reply:i normally put those in a ultrasonic hot tank with power clean for about 30 mins and weld away and weld and clean weld and clean till it cleans upjust did a 2 stroke engine case last week welded right up after it came out of the hot tankMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:I find that running the AC arc quickly over the parts first brings alot of the contaminants to the surface. Re-wirebrush after and have a go at it.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Unless you can clean both sides your fighting an uphill battle.....The oil must be cleaned away and the casting skimmed off with an angle head sander to get down to clean parent metal. Use more Electron Positive when you set your amplitude and 4043 filler I would even die grind into the weld joint for more strength creating a weld prep, maybe 3/8 wide and close to the thickness of the material for a 100%pen weldLast edited by B_C; 06-07-2013 at 12:57 PM. Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock |
