i need some 8/3 wire..
发表于 2021-8-31 22:46:07 | 显示全部楼层 |阅读模式
any good sources for such an item?i also need some welsing leads..i have a maxstar 200DX what size leads should i be running off that machine also?
Reply:You Should Be Able To Buy It At Lowes Or Home Depot I Believe It Is 30amp Wire Like For A Dryer And 6 Is 50amp I Think Been A While Since I Wired Anything And For Your Leads Depends On Length Of The Circuit And Max Amps I Run #1 At 75ft Of Each And It Rated At 250 But Pushing It I Really Shoul Have 1/0  Hope This HelpsChad Ware
Reply:8/3 how long of a cord are you making.......that maxstar would be good to 150 + ft with 8/3.....as for leads the dins conecctors will limit your size....unless you drill them outMike
Reply:You can comfortably use #2 cable forever. That will fit into your Dinse connectors also. weldersales
GMT+8, 2025-12-29 18:49 , Processed in 0.107787 second(s), 18 queries .
