Invertec V100-S with tig pedal mod for sale
发表于 2021-8-31 22:46:03 | 显示全部楼层 |阅读模式
I'm selling my little Lincoln Electric inverter welder.  Runs on 110V, 100 amp output, DC only.  It works great.  I've used it very sparingly, pretty much just to learn basic stick and tig welding, so I've only run beads on some flat plate.  I've also modified it for a pedal to adjust the heat settings.  The pedal is a plastic sewing machine pedal, and it works perfectly.  The switch on the front panel allows you to switch between the pedal and panel knob to adjust the current.  Everything works perfectly, I've only put maybe 5 hours of tigging on the unit with the pedal.What you see in the pics is what's included.  The list is the unit itself, an extra electrical outlet plug that Lincoln provided, the stick electrode holder, ground clamp, pedal, and manual.  I even have the original shipping box the welder came in, so I can ship as necessary.  Shipping cost is actual shipping from zip code 92647.Pics:Web page here: http://www.mylincolnelectric.com/Cat...et.aspx?p=2498I'm selling it to add to my fund to purchase an ac/dc welder so I can start learning how to tig aluminum.  I am asking 300$.Please feel free to PM me or post.  Welder is located in Huntington Beach.
Reply:Iweasel, if you have a good slingshot, you can hit my house from where you are at!!! My zip is 92647 also..... call me, I am actually thinking I may need another 110v welder. And, if you want to practice aluminum, I have an inverter Lincoln here at the house you can use. Paul. 714-801-5514And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:Still available.  Paul if you're interested please PM me and I can bring it over some time.
Reply:Still have it?
GMT+8, 2025-12-29 18:49 , Processed in 0.097300 second(s), 18 queries .
