Miller Invision 304p's and 456p's
发表于 2021-8-31 22:46:02 | 显示全部楼层 |阅读模式
I have a couple Miller mig inverter welders for sale. They are the Invision models 304'p & 456p's and require 3 phase power. These inverter power sources list for about $5300. Check millers website!!  If you have any questions about them let me know. I will do the best I can to answer them! I also have some of millers S-64M microprossessor feeders. New these feeder costed around $3600. They have the ablility to allow you to pulse weld. This allows you to greatly control the amount of spatter that you produce which means you can greatly reduce your labor in sanding or grinding of spatter not to mention the amount of money you will save on sanding  discs, belts, and grinding wheels!! If your interested drop me a email. My email is [email protected] I have several of these sets if your interested let me know. I use one of them for my needs and it is absolutely amazing. You can program up to 8 separate welding programs into the feeder so at the push of a button! The feeder automatically switches to a completely different welding setting they you programed into it. It also has factory set welding programs for just about any kind of wire you could run through it. Oh and it will weld stainless, aluminum, and all kinds of cored wires. Give me a shout if your interested in a top of the line mig welder and remember 3 phase power only! That means no it will not run on single phase so please dont ask!!! If your serious I can send you some pics once you email me!!
GMT+8, 2025-12-29 20:44 , Processed in 0.098624 second(s), 18 queries .
