Rose gate
发表于 2021-8-31 22:46:00 | 显示全部楼层 |阅读模式
Finished my summer project and I like to share a few pictures.I upgraded the wooden rose gate:  The side decorations were (plasma-) cut out of 20g sheets:    The foundation is about 500# of concrete in each side. The 2x4 keeps the rebar frame with the bolts in place until the concrete is solid.  The square tube is bend using a HF roller and is cut later to the final size:  Now the bowed top will be connected with the vertical tubes.One side is 9cm/3.5" longer than the other because of the slope of the walkway.The side segments are made out of 3/8" square:  The frame is mounted and the gate is done!
Reply:Very nice! Like to make a few of these for some future presents.
Reply:Sharp work & nice yard!
Reply:Thanks for your comments
GMT+8, 2025-12-29 18:49 , Processed in 0.098025 second(s), 18 queries .
