Pig Smoker Question
发表于 2021-8-31 22:45:57 | 显示全部楼层 |阅读模式
Wanna make a tow behind Smoker like i seen on this site. I Want to know if i can actually BURN out oil from a used oil tank.  I don't think it sounds to safe, and have seen some old ones converted.  Just don't wanna spend the $$$ on a new tank just to cut it up.  Any opinions or suggestions on Using an OLD Tank and Burning it clean or just going NEW.  Or even Will a Propane Tank be better and what size do people Suggest.  Im From the Outskirts of Philly so i aint a True Country Boy and could use some HELP!!! Attached ImagesMiller Bobcat 250Miller Maxstar 140strLongevity 140 migSnapon Muscle Mig/tigHypertherm Powermax 30
Reply:I don't know but DAMN!... you shonuff made me hungry....Miller Bobcat 250Miller Multimatic 200 Miller & 3M PPEHobart electrodesDeWaltz toolsPT standsVictor MD torchRadnor HD  torch
Reply:get it raging hot inside and carry on IMO.  I don't see the big difference between LPG or diesel as far as contamination goes.  That's my non-technical answer.  Tons of those cookers around here, all former oil tanks.
Reply:Snoop around this site, lots of good info and a good bunch of guys.http://www.thesmokering.com/
Reply:Ditto on all the advice so far.  I have built one cooker out of a drum like that.  Fire it up and let it burn off.  Then season it.It would be good if the drum doesn't have any oil in it when you cut it.  That could be a bad thing.ECAVE Still learnin'Lincoln AC225Lincoln 135SPHF ChopsawVictor O/ANumerous other items
Reply:You say season it. Do you mean with vegetable oil ? And what's the best way to make sure there's now oil. Keep filling and draining it with water?  That can't be to EPA freindly. Sent from my iPhone using Tapatalk - now FreeMiller Bobcat 250Miller Maxstar 140strLongevity 140 migSnapon Muscle Mig/tigHypertherm Powermax 30
Reply:I like that design. The one we used to have was turned the other way. It's been way too many years, but I'm pretty sure ours was a "repurposed" one that had been burned out really well..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by BadFitUpYou say season it. Do you mean with vegetable oil ? And what's the best way to make sure there's now oil. Keep filling and draining it with water?  That can't be to EPA freindly. Sent from my iPhone using Tapatalk - now Free
Reply:BURN IT! Ain't nothing in the oil going to put more carcinogens (yup that's spelled wrong, but I don't GAF) in the food than the fuels that you are smoking the meat with anyway. and if you burn it out really hot you'll burn out anything that would have burned out at the lower smoking temps anyway. just get her good and hot. I used a leaf blower to add air to get the fire as hot as possible. worked a charm.you should drain as much oil as possible before doing this. no point in adding more crap to the air as you need too. I drained, washed, filled with water, cut, washed, wiped and then burned.Last edited by ThorsHammer; 09-18-2013 at 12:53 PM.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Like ThorsHammer said, fill that thing with water before you cut into it.  That way it displaces all the fumes of any possible oil/fuel in there.  It's the fumes you really have to worry about, don't ask me how I know.Craig MontgomeryM&L Fabrication, LLChttps://www.facebook.com/pages/ML-Fa...8228829?ref=hl
Reply:Haha. Big tank go BOOM! Lol. Yea thanks guys. Got ahold if a 2 years old fuel oil tank for $125. Great shape. Gonna flood it next week and I guess Use a cutting wheel.  Really wanna use my Plasma but. I have kids so I am not gonna play dumb.  Sent from my iPhone using Tapatalk - now FreeMiller Bobcat 250Miller Maxstar 140strLongevity 140 migSnapon Muscle Mig/tigHypertherm Powermax 30
Reply:I can't say I consider an abrasive wheel that much safer than the plasma.   I'd fill it up with water and tip it so that you can cut in what little air space there is and get at least one nice long cut ripped before the water drains.  That way, in the event of a "woof" of the fumes, it can release some pressure out the gap and not try to explode.  That's what I aim for at least, to get a big hole cut in it with as little air space as possible, after that, it's no longer enclosed.
Reply:There is the odd barbecue like this around here.......hee hee hee.Lots of them and I man lots of them have been built out of old propane tanks. In fact used one go at quite a price because of the texas smoker barbecue builds.I recommend you use an old propane tank for your build.Good lick. Post pics pls.GlennSign on East Texas payphone: Calls to God 40 cents......it's a local call...
Reply:Here is the one I built last winter.  Used a 250 gal propane tank.  I also follow the Smoke Ring web site.  I let my tank set open with all plugs out for a month then purged with the tail pipe off the truck while cutting with a waffer wheel.  On diesel tanks I use a sawz-all. Dan
Reply:Thanks for the responses. Been hunting down propane tanks for a while can't find one. Love that big boy tank but hard to find up here. Sent from my iPhone using Tapatalk - now FreeMiller Bobcat 250Miller Maxstar 140strLongevity 140 migSnapon Muscle Mig/tigHypertherm Powermax 30
Reply:Add your location in your profile, it might be that someone near you has a lead on a good tank. I just got hold of a used LP tank from a motorhome. Not as large as a residential tank, but it is larger than my first horizontal smoker.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
GMT+8, 2025-12-29 18:49 , Processed in 0.100046 second(s), 18 queries .
