I've got a Thermal Arc 211i and have been learning to scratch start TIG with it. I'm having an odd issue where I start the weld normally, but when I let off the trigger at the end of the weld it takes the arc 5-8 seconds to die out, making big fat craters at the end of my weld. Is this normal, or is something wrong with my welder?
Reply:Check your owners manual for a feature called "crater fill", this allows for a release or activation of this feature when you get to the end of a weld. There may also be an adjustment of the specific time that this occurs over or the duration. Good luck and best regards, Allanaevald
Reply:Turn the downslope off.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by mortimersnerdI've got a Thermal Arc 211i and have been learning to scratch start TIG with it. I'm having an odd issue where I start the weld normally, but when I let off the trigger at the end of the weld it takes the arc 5-8 seconds to die out, making big fat craters at the end of my weld. Is this normal, or is something wrong with my welder?
Reply:It has no foot pedal, but does have a trigger on the gun. Its a multi process welder that does mig, dc tig and stick. It doesn't have crater fill, and I don't think it has downslope but I'll double check.
Reply:The literature says it has downslope.Last edited by MinnesotaDave; 01-18-2015 at 11:48 AM.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:^it's the middle knob. it says right on the front panel...Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Thank you! Found that this morning. Will play with it ate i get done at the doctor, got a piece of steel in my eye last night.
Reply:Thanks guys, messing with the downslope fixed it.
Reply:Originally Posted by mortimersnerdThank you! Found that this morning. Will play with it ate i get done at the doctor, got a piece of steel in my eye last night. |
