TIG gloves What do you use
发表于 2021-8-31 22:45:46 | 显示全部楼层 |阅读模式
I got a pair of  BSX black  cloves.  They are supple enough bot leave black stain on my hands and they are heat magnets. What do you do to beat the heat? White gloves like Lincoln'sHey~!! It's a hobby. It's not supposed to make sense~!!
Reply:I wear Tillman 30M gloves for tig. They still get hot..They are tig gloves, the burning means its working. After a few blisters you will find ways to prevent them most of the time, but you will get uncomfotably hot sometimes. Theres no way around the heat. Get used to it, your welding. Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:I used the BSX black gloves too.  I like them, they are almost like batting gloves, and it gives me great control over the filler wire and tig torch..  As for heat, sometimes you can't be a Pu$$y. lol
Reply:Black tillman onyx are good until they shrink. Other than those, the standard tillman gloves work good. I don't care for their leather ones.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Black Tillman onyx for me too. If your bothered by the heat, try recycling an old set of leathers by using a piece to rest your hand on. I do this on odd shaped parts where I have to prop my hand on the piece I'm welding. It don't make your hand fireproof, but sometimes it's enough to get that extra inch you need to finish without stopping. And remember, welding in controlled melting of metal. Get used to the heat
Reply:Work buys me these.[ame]http://www.amazon.com/Steiner-0260L-Ironflex-Gloves-Kidskin/dp/B0034RZNFI[/ame]Love them! They are double padded right on the heel of the hand, really helps with the heat while sliding your hand along the work piece.If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:Ill give some shamless free advertisement to the guy at weldingtipsandtricks.com. His "TIG finger," is really a neat product. Once you get used to it, it can really help you beat the heat.
Reply:Originally Posted by larpheadWork buys me these.http://www.amazon.com/Steiner-0260L-.../dp/B0034RZNFILove them! They are double padded right on the heel of the hand, really helps with the heat while sliding your hand along the work piece.
Reply:The tilman tig gloves suck nuts and always tear at the thumb/palm stitch. People at tilman apparently don't know what a hand is shaped like.I now use Miller tig gloves, they literally last 2-3 times longer and cost only a few dollars more, you're getting alot more for your money. MUCH better build quality and comfort, double stitched unlike tilmans. http://www.weldfabulous.com/p-20093-...ves-large.aspxWelding/Fab Pics: www.UtahWeld.com
Reply:Originally Posted by MikeGyverThe tilman tig gloves suck nuts and always tear at the thumb/palm stitch. People at tilman apparently don't know what a hand is shaped like.I now use Miller tig gloves, they literally last 2-3 times longer and cost only a few dollars more, you're getting alot more for your money. MUCH better build quality and comfort, double stitched unlike tilmans. http://www.weldfabulous.com/p-20093-...ves-large.aspx
Reply:Originally Posted by tig dummyThese are all I use I love em. Just enlarged the pic and I was wrong. The ones I use are from BSX but look identical.http://www.amazon.com/Black-Stallion.../dp/B0035XAOAA
Reply:Originally Posted by GambleWhy are the small and medium gloves more expensive than the rest? That's the most expensive glove I've seen. Tell work you want a medium and send it over
Reply:http://jtillman.com/products/gloves/mig/48/I use these. For everything except flux core, then I run a stick glove on my left hand and one of these on my right. I've been through 3 pairs of them so far, I love them!
Reply:I wear two different gloves, a mig glove on my torch hand and a tillman tig glove on my filler hand.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:I've been using tigsters. It seems to be a good balance between dexterity and heat protection and they are available in XXL which is a plus for me.
Reply:Originally Posted by Wes917Work buys us the ****ty tilmans. How are these with smaller wire. When I have to use .030 I tend to not use a glove bc the tilmans suck.
Reply:Torch hand gets this..http://www.bakersgas.com/till1001.htmlFiller hand gets nothing.Safety police can keep to yourselves.We have heard it all before.  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I only wear Northern Tools heavy leather roping gloves,sometimes I switch and wear a heavier stick welding glove on my torch hand...Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Cool.  So the most heat reflective glove out there appears to be white augmented by the little heat shield that Jody sells.I did a search for heat reflective glove  instead of using phrases like TIG or welding and found  quite a selection of silvered gloves. None looked particularly close fitting like a TIG glove In the spirit of  "Nothing Ventured, Nothing Gained," I'm going to try something goofy.I  have some highly reflective spray paint. Mine is  gold but there's a silver too. I'm gonna spray paint a leather work glove and see if the reflective paint ( a) doesn't burn off, (b) doesn't flake off,  and of course (c) reflects substantial heat.Hey~!! It's a hobby. It's not supposed to make sense~!!
Reply:Originally Posted by zapsterTorch hand gets this..http://www.bakersgas.com/till1001.htmlFiller hand gets nothing.Safety police can keep to yourselves.We have heard it all before.  ...zap!
Reply:Originally Posted by Oscartell me about it.   I have small hands and I loathe loose fitting tig gloves!
Reply:Tillman kidskin all the wayMike
Reply:Originally Posted by RaulCool.  So the most heat reflective glove out there appears to be white augmented by the little heat shield that Jody sells.I did a search for heat reflective glove  instead of using phrases like TIG or welding and found  quite a selection of silvered gloves. None looked particularly close fitting like a TIG glove In the spirit of  "Nothing Ventured, Nothing Gained," I'm going to try something goofy.I  have some highly reflective spray paint. Mine is  gold but there's a silver too. I'm gonna spray paint a leather work glove and see if the reflective paint ( a) doesn't burn off, (b) doesn't flake off,  and of course (c) reflects substantial heat.I use plain old leather work gloves - but they are deerskin so they are super soft - $9.95I also use Jody's tig finger.  Love it cause I can drag my hand on the plate I only wear long cuff gloves with stick.Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Miller Tig gloves. The long cuff ones
Reply:Originally Posted by SquirmyPugJust don't let any welders..Or any of your friends see you wearing gold or silver gloves.
Reply:http://www.newegg.com/Product/Produc...9SIA1850BC2012I'm running these right now, they work.(Home)Miller Maxstar 152 (sold)MM211/spool gunLincoln AC 225C(Work)Dynasty 350Powcon 300STLincoln SP-175TWeldlodgic AWS150sWeldlodgic AWS300Custom Resistance seam weldersCambridge Vacuum EB weldersI smell something burning.
Reply:I found these http://www.akka.ca/eng/gloves/heat-r.../GTAC_D27.htmlResist 250 C under $10.00  & don't look too clumsy Today I grabbed some silver aluminized heat shield material with a PSA adhesive backing and wrapped some of it around the fingers of my TIG gloves. Made a H-U-G-E difference. Was not cumbersome.Hey~!! It's a hobby. It's not supposed to make sense~!!
GMT+8, 2025-12-29 20:22 , Processed in 0.116054 second(s), 18 queries .
