I finally did it!
发表于 2021-8-31 22:45:45 | 显示全部楼层 |阅读模式
Finally passed my unlimited thickness 3G. Took about 5 times.Miller Maxstar 200 SDPiperliner #10 Gold
Reply:.   Finally passed my unlimited thickness test. It took me about 5 times. Time to move onto overhead.Miller Maxstar 200 SDPiperliner #10 Gold
Reply:Sorry bout double post i don't know if the pictures work ill fix when I get home since I'm on my iPod at school.Miller Maxstar 200 SDPiperliner #10 Gold
Reply:Their we go, d@mn iPod Had 2 small indications but both were less than an 1/8" of an inch added together.I guess I get some type of qualification thing.Miller Maxstar 200 SDPiperliner #10 Gold
Reply:Congrats! [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Originally Posted by 7A749Awesome!!!L
Reply:Good for you bro clap clap! Vertical up? What size rod?I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by weldermikeGood for you bro clap clap! Vertical up? What size rod?
Reply:Good going bud, I had to get that cert and overhead a long time ago. It was murder, during the summer hot as a bastard and did both of them back to back. 4hrs straight burning rod. I had to use 5/32 tho. Nice job there bud congrats I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Congrats..It only took you 5 minutes from start to finish for that test? Damm, you're quick.. It takes me alteast a minute or two to fit up  and tack the test plates.Weren't you worried about the plate getting to hot and the weld drooping down.. The last test I took, it was only 3/8ths plate, I did it in 3 passes, but waited a bit to do the cap so it looked nice..
Reply:Originally Posted by ShortbusWelderCongrats..It only took you 5 minutes from start to finish for that test? Damm, you're quick.. It takes me alteast a minute or two to fit up  and tack the test plates.Weren't you worried about the plate getting to hot and the weld drooping down.. The last test I took, it was only 3/8ths plate, I did it in 3 passes, but waited a bit to do the cap so it looked nice..
Reply:Originally Posted by weldermikeGood going bud, I had to get that cert and overhead a long time ago. It was murder, during the summer hot as a bastard and did both of them back to back. 4hrs straight burning rod. I had to use 5/32 tho. Nice job there bud congrats
Reply:Originally Posted by smilexelectricIt took me 8 hours to do it, 2 passes cool, 2 passes cool. Till I got close to the cap I could run more.
Reply:Congrats. Is always feels good to pass a welding test and get a ticket. I recently took my CWB 4 position stick plate test and passed all 4 the first try. Flat, horizontal, vertical up and over head. Had all 4 tests welded in 3 hrs with 1/8 7018.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Originally Posted by ShortbusWelderOh, I was going to say, no way it could take one only 5 mins, but I been wrong.   My reading skills were off, where it said 5 times, I swear it said 5 minutes. lol Congrats again though.What's the next test?
Reply:CongratulationsHey~!! It's a hobby. It's not supposed to make sense~!!
Reply:Congrats Good luck with the 4G
Reply:Originally Posted by snoeproeCongrats. Is always feels good to pass a welding test and get a ticket. I recently took my CWB 4 position stick plate test and passed all 4 the first try. Flat, horizontal, vertical up and over head. Had all 4 tests welded in 3 hrs with 1/8 7018.
Reply:Congrats man! I go in for the same test Monday. Any pointers for me would be appreciated.
Reply:Originally Posted by BlueArc1" or 3/8" plates?Around here they only make you test 3g and 4g, and passing 4g covers 1 and 2. What kind of work do you do that makes you test in all four?
Reply:Originally Posted by Ranger250gxtCongrats man! I go in for the same test Monday. Any pointers for me would be appreciated.
Reply:Originally Posted by snoeproe3/8" plates. A stop and re start on each root pass. Cut into 3 coupons, 2 root bends (each stop and restart) and a face bend on the cap. I do union construction work, fab work and mobile heavy equipment repair work.
Reply:Good job! Feels good when you know you passed. Bet you were nervous all day.Hickory
Reply:Congrats!If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:Originally Posted by HickoryGood job! Feels good when you know you passed. Bet you were nervous all day.
GMT+8, 2025-12-29 22:00 , Processed in 0.389233 second(s), 30 queries .
