Linde UCC 305 with cooling tank and foot control
发表于 2021-8-31 22:45:43 | 显示全部楼层 |阅读模式
I wish I knew more about welding and equipment, so I could give a better description.  I weldonly as a hobbyist, and not for a living.Up for auction is a Linde UCC 305 combination TIG and Stick welder.  Very heavy duty.   Thisis not the cheapo 200 model  or the cheapo 300 model.   Includes a huge bottleof Argon that shows over 2500 psi (about 3/4 full), along with the working regulator / flowmeter.  I have no paperwork for the bottle.Also includes a cart/cooling water tank.  The pump works fine, there are  no leaks.  I have no wayof verifying, but the guy I purchased this from said it had a 40 gallon cooling capacity.  Looksabout right, but I have no way of measuring.This thing is much bigger in person that the photos make it appear.  That is why I am selling it.  Ijust don’t have room in my garage for this.  It is also very heavy, somewhere between a thousandand two thousand pounds.  You will need to bring a car hauler or something equivalent with awinch, to load this.  It took three guys just to roll it up my driveway and into the garage.  If youlive in the OKC area, I have access to a car hauler, and can assist you in getting it to your place.  Iwill not charge to do this.  However, I will need your help (and probably a couple of yourbuddies) to get that done.  So, don’t just expect me to “deliver” for you.Dimensions include:                    Overall height:     60 inches                    Overall width:      40 inches                    Overall length:     52 inchesMain case H/W/L is 42 x 30 x 35 inches.From the floor to the top of the bottle is 66 inches, with the bottle on the cart.Lead for stick welding and the grounding cable are each about 22 feet.Power cord is 20 feetTIG leads (torch and foot control) are 20 feet.I purchased this on ebay last year and have only used it a couple of times.  It works flawlessly.  Ihave a 50 amp plug on it and only used it in the lower amperage ranges.  If you have 60 ampservice, the plug can be changed.  It runs on SINGLE PHASE 220, so you will not need to bringin expensive three phase power.This is not the cheaper built 200 or 300 model.  This is the heavy duty unit, described by oneprofessional as “first Linde built machine was the UCC305 and is widely used today - one of thebest bargains on the used market. Very nice form factor, flat top, workbench height. Inexpensiveto maintain. Truly bullet-proof and able to work with the new finger tip controls.”You are welcome (even encouraged) to come try it out before purchase.  As I said, everything works perfectly.Pictures can be viewed here:http://s74.photobucket.com/albums/i2...t=HPIM3255.jpghttp://s74.photobucket.com/albums/i2...t=HPIM3250.jpghttp://s74.photobucket.com/albums/i2...t=HPIM3248.jpgI would take $800 for it, and that will still leave me with a bit of a loss.  I am listing on ebay, but if someone on this site purchases for $800, I will stop the ebay auction, provided the bidding has not exceeded that amount.  Being I am a newbie here, I will also make a donation to the site (you guys do accept donations, don't you) if it sells to someone here.Thanks.Lynn [email protected] 826-6805 cell phone
GMT+8, 2025-12-29 20:44 , Processed in 0.100194 second(s), 18 queries .
