Suitcase Feeder Wanted
发表于 2021-8-31 22:45:43 | 显示全部楼层 |阅读模式
Looking for a portable feeder..Prefer LN-15 or LN-25,but will consider any... Send PM or Reply here .. Thanks, Steve
Reply:You are probably thinking of an arc voltage feeder - one that will run off any dc welder, mig or stick. They start here for about 400.00. If you want to  run gas, you probably want a gas solenoid and most people want contactors so that the wire is cold until trigger pulled. Feeders with these options start about 500.00 and go up. Later Millers and Lincolns start about 700.00 here. weldersales
GMT+8, 2025-12-29 20:23 , Processed in 0.092541 second(s), 18 queries .
