custom bracket, tabs, and gussets
发表于 2021-8-31 22:45:41 | 显示全部楼层 |阅读模式
ALL TYPES OF GUSSETS AND TABS FOR SELL JUST TELL ME WHAT YOU WANT AND i'LL GET'EM [email protected] arn't done just used to show the veriety of tabs and gussets
Reply:Why do you need to grind them?Free Hand Cut?Me!
Reply:naw these are just to show the veriaty of  tabs and gussets the ones being sold are not grounded, the finised products are flawless.
Reply:how do you cut the holes and the edges without burrs? even plasma cams leave some sort of slag behind. not knocking your skills or anything... just curious as to how you can get such clean parts with no defects.Later,Andy
Reply:Originally Posted by aczellerhow do you cut the holes and the edges without burrs? even plasma cams leave some sort of slag behind. not knocking your skills or anything... just curious as to how you can get such clean parts with no defects.Later,Andy
Reply:With an oxygen based high definition plasma....on a precision cnc machine with a good height control system.....these type of parts are very easy to produce with virtually no secondary operations such as grinding. With an air plasma..on a good machine...any fine features and holes will be somewhat drossy...but the dross is easy to remove. Laser and water jet can also produce very nice dross free parts out of carbon steel...generally with higher accuracy than plasma....but at much slower speeds and at considerably higher operating cost.Plasma parts like these can be produced on a production basis with tolerances in the plus or minus .015" range.....laser and abrasive water jet in the plus or minus .005" to .010" range.Jim
Reply:They actually look like he is hand cutting them with a plasma cutter using template or something, then grinding the edges and drilling out the holes. My plasma cam leaves some dross on the edge, but it falls right off when you tap it with a hammer. Those dont look uniform enough to be CNC'd.Miller Syncrowave 200Hobart Handler 140Thermal Dynamics Cutmaster 38E-Z Tube BenderPlasma Cam DHC2
Reply:I was thinking the same thing Q. Although the top ones look like the holes may have been punched. Hard to tell from the pic's. Most welder fabricators make things like this up all the time.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Not trying to knock you Magnetic_Re, but it just seems wierd to try and sell gussets and tabs on a welding forum. Most guys here take pleasure in doing this kind of stuff themselves. You should try a 4x4 forum or something.Miller Syncrowave 200Hobart Handler 140Thermal Dynamics Cutmaster 38E-Z Tube BenderPlasma Cam DHC2
Reply:Those are hand cut no doubt. Show us something flawless and maybe I'll be interested.Patriot Performance AutoLincoln Power Mig 255CLincoln AC-225 StickVictor Journeyman O/AQuincy QT-5 Compressor
Reply:Proto-fab knock off?They stamp theirs from cold rolled and are very, very clean.Last edited by 9er; 03-29-2008 at 12:34 AM.
Reply:just trying to make some cash with the tools I got.. Thanks I'll get'em looking flawless
Reply:Just an FYI,  It's not really worth making them by hand.Simple tabs like you have pictured are available for about $0.11 to $0.25 a peice.  And the gussets with the holes go for $0.19.  Even cheaper in bulk quantities.
GMT+8, 2025-12-29 20:32 , Processed in 0.074235 second(s), 18 queries .
