Dake Cold Saw Super Technics 350 FOR SALE
发表于 2021-8-31 22:45:40 | 显示全部楼层 |阅读模式
New this was $5475. EXCELLENT price at $3600. This is 2 years old. It was lightly used 8 months in a small shop. Great condition. It has 2 extra blades with it. Head rotates 45 deg. Right and left of center for miter cutting. Oversized spindle and gear assembly with splined steel shaft and heavy duty bronze gear. Additional ball bearing support of hardened and ground spindle shaft to prevent failure. Reliable mechanical coolant pump with flow control adjustment 350 models all feature 24v control circuit, E-stop switch, low voltage and thermal protection, 3 phase motor 350 model additional features: Adjustable clutch to prevent blade breakage High speed ideal for non ferrous material Head rotates 90 degrees for slot cutting operations This is a great machine, we just are not using it.We will crate it but buyer must pay shipping or pick it up. Deliverly may be possible in Texas for additional cost."C" Attached Images
Reply:I'll see what the tax man brings me this year. I would really like to have a cold saw. Edit: I just seen its 3phase, no can do in my shopPatriot Performance AutoLincoln Power Mig 255CLincoln AC-225 StickVictor Journeyman O/AQuincy QT-5 Compressor
Reply:If you do not have 3 phase but would like it you can go to www.phaseconverter.com  and get a 5KW converter. It is $595 but they have a special price if you call. The HP is 2- 3.5 depending on the speed you are running the saw. I am sure you can find a better price, this was just a quick bit of info.
GMT+8, 2025-12-29 20:21 , Processed in 0.155580 second(s), 18 queries .
