gold lens ?
发表于 2021-8-31 22:45:35 | 显示全部楼层 |阅读模式
I just ordered a gold lens and was wanting to learn more about how they work and what they are good for. A class mate and instructor pointed me to a gold lens .... for better vision?
Reply:Originally Posted by t-langI just ordered a gold lens and was wanting to learn more about how they work and what they are good for. A class mate and instructor pointed me to a gold lens .... for better vision?
Reply:If I remember correctly the main purpose of the gold coating is to reflect radiant heat away from your eyes creating less heat build up in your hood. The filter lense filters out everything in normal fashion.Ranger 250 thick stuffHobart Handler 140 not thick stuffthe pane and oxy setup
Reply:You don't get the green tint link you do with standard green lenses. You get more of the colors and better clarity. Just stay away from'Weldmark brand as sometimes the gold is put on poorly and you will see orange. Omniveiw, AO weld cool, and Phillips safety put out good lenses.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:I have used a gold lens for years.  You get a very clear view of the puddle.  Hope you like it.
Reply:KWS for the win.  Spot on.  http://blog.phillips-safety.com/gold...elding-lenses/Phillips Au lenses rule!"Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:here's a link to the best gold lenses available now... as close as you can get to the old AO gold lenses... just got my first one this wk.... after using all wk my eye's feel so much better!!! won't find anyting even close at local welding supply store's... just ordered me 2 more and a coworker 2.. here's his ebay link.. http://www.ebay.com/itm/281545157508...%3AMEBIDX%3AITall the gold lenses you find locally are no better than standard green lenses... this ebay seller is great to do business with... your eye's will thank you for using them.. hope this help's anyone that has been looking for the old school type gold lenses...
Reply:The gold coating reflects IR and also bounces light back at the weld. This is helpful for seeing the edges of a bevel since the arclight might normally not directly light up anything outside of the bevel.Welding/Fab Pics: www.UtahWeld.com
Reply:Gold is the ticket. I have had mine for almost 20 years. I also have a silver lens that I love. I switch back an forth from time to time just to switch it up. The clarity is awsome. I am still looking for an AO Cool blue lens... just throwing it out there. Lol.
Reply:thanks
Reply:finally got to use the gold lens today it did not disappoint . I could see everything so much better.
GMT+8, 2025-12-29 20:44 , Processed in 0.101266 second(s), 18 queries .
