What is 4 way clamping in Structural Steel Welding?
发表于 2021-8-31 22:45:33 | 显示全部楼层 |阅读模式
Hi All,I have heard about 3 axis clamping system used in structural steel weldings, but came to know there is 4 way clamping method also? Can you pls give me more guidance on this?- How it is used in Structural Steel welding?- It will be great if you can share any weblink for pics or videos on this.Thanks a lot!AK
Reply:I weld structural steel for a living. What are you wanting to clamp? My most used clamp is a bessy clamp. Nothing fancy required. I'm not familiar with what your asking about?JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:http://www.northerntool.com/shop/too...2945_200342945That would be a 3 way axis clamp, im guessing a 4 way clamp would be refered to using a jig table with dowel holes or threaded holes with finger clamps?Nothing Ever Got Done By Quitting, Never Give Up.
Reply:Think I'm about to learn something here. I've done a little structural welding, mostly used these. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Honestly, I can use a simple square, tape measure and a level to accomplish what that 3 way axis clamp will do. The level and square will do it much more quickly. No messing around with that fancy clamp. I've never worked for a company who supplied anything like that and I do lots of work in the Ironworker fab shop.$200 for that 3 axis clamp at Northern. I wonder if they have one that will hold 8" or 12" I beams?Last edited by snoeproe; 01-21-2015 at 10:58 PM.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2025-12-29 20:41 , Processed in 0.094191 second(s), 18 queries .
