Has anyone ever successfully carried a suitcase welder on an airplane? I need to fly with one but don't want to check it. It would be the power source only. I don't see any regulations preventing it specifically. ThanksMiller 250DXTD Cutmaster 100Duct TapeBFH
Reply:I think that you are going to get a few funny faces at the security check. If I were you, I wouldn't even try. Any chance you can specifically call the airport and ask them? When in doubt, get there with plenty of time ahead and go straight to the security check. Ask them if you can get through with this. If not, check it or ship it.
Reply:I wouldn't let baggage handlers touch a Dynasty either! Damn thing would have to be bubble wrapped and suspended in an anti-gravity field to be safe...Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:It's a pile of electronics that could easily be a bomb in the eyes of Tsa.I would doubt they would allow it.Try and call them anyway, tho.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:call it a Welding Computer at Security check.We fly with Photo gear that has just as much electronicsEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Put it in a hard case, pack a small firearm in a soft case in same case. Check the case at check in. Lock it with your own NON TSA lock. Go to special screening area. Now no one can open it without you present or unless they get search warrant.If you are flying to one of the communist places like NYC make sure it's compliant with their laws or you can be arrested after arrival. Even if your plans is detoured there.Tiger Sales: AHP Distributor www.tigersalesco.comAHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma. For Sale: Cobra Mig 250 w/ Push-pull gun. Lincoln Wirematic 250
Reply:These cases work purrfect for flying and fit the standard 62" luggage dementions Attached ImagesTiger Sales: AHP Distributor www.tigersalesco.comAHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma. For Sale: Cobra Mig 250 w/ Push-pull gun. Lincoln Wirematic 250
Reply:Even circa 1990 airlines didn't like unfamiliar carry-on boxes that had a display and places to connect wires.Post-911 I saw an old Chinese gent get questioned for trying to carry on a high end record player tonearm. Screener had no clue what it was."USMCPOP" First-born son: KIA Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Thank you for all the replies. I'll see what I can come up with. Oldendum, thank you for your family's sacrifice. Semper FiMiller 250DXTD Cutmaster 100Duct TapeBFH
Reply:Originally Posted by soutthpawPut it in a hard case, pack a small firearm in a soft case in same case. Check the case at check in. Lock it with your own NON TSA lock. Go to special screening area. Now no one can open it without you present or unless they get search warrant.If you are flying to one of the communist places like NYC make sure it's compliant with their laws or you can be arrested after arrival. Even if your plans is detoured there.
Reply:I would say carry the 120vac adapter so you can power it up if necessary and show them it operates. Maybe the sales brochure from Miller tooLast edited by soutthpaw; 01-20-2015 at 03:49 PM.Tiger Sales: AHP Distributor www.tigersalesco.comAHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma. For Sale: Cobra Mig 250 w/ Push-pull gun. Lincoln Wirematic 250
Reply:Originally Posted by rlitmanI remember a reporter years ago advocating that. But he figured out that while a flare gun is not considered a firearm in most states, it is treated just like one by the airlines, so he packed flare guns in his luggage. Not sure how well that worked out for him though
Reply:Can you Fed-Ex it there a few days in advance so it will be there before you?
Reply:You can pack a starter pistol as well.One important note, when you check in the baggage, you must declare it has a firearm in it. That's what gets the process rolling. At that point the bag WILL be checked manually (presumably by TSA directly) and carefully watched.Note, declaring you do have a firearm in a bag and not actually having one will get you in trouble.The starter pistol should be OK no mater where you go.Con Fuse!Miller Dynasty 350Millermatic 350P-Spoolmatic 30AMiller Multimatic 200Hypertherm PowerMax 1000G3Miller Maxstar 200DX
Reply:Originally Posted by con_fuse9You can pack a starter pistol as well.One important note, when you check in the baggage, you must declare it has a firearm in it. That's what gets the process rolling. At that point the bag WILL be checked manually (presumably by TSA directly) and carefully watched.Note, declaring you do have a firearm in a bag and not actually having one will get you in trouble.The starter pistol should be OK no mater where you go.
Reply:Originally Posted by BistineauCan you Fed-Ex it there a few days in advance so it will be there before you?
Reply:I have had TSA disassemble a speed controller and send the pieces.
Reply:Originally Posted by arcflashI have had TSA disassemble a speed controller and send the pieces.
Reply:Sending it fedex or ups would be the best thing to do, its cheaper than dealing with all the headaches and possibly loosing it in the airport. If I had to carry a welder with me I would rather drive to my destination and enjoy the scenery. JMO
Reply:Fed x gonna be about $380.00 Overnight 8:30am$340.00- 10:30am$330.00 3pm2-day: $297.00 10am$186.00 4:30pmIt aint cheap.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by Broccoli1Fed x gonna be about $380.00 Overnight 8:30am$340.00- 10:30am$330.00 3pm2-day: $297.00 10am$186.00 4:30pmIt aint cheap.
Reply:Photo and Video gear is sent on planes all the time. I wouldn't worry about checking the Dynasty packed in a good pelican style case. We do it all the time. Consumer stuff gets stolen out of luggage more frequently than professional equipment.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I've seen guys travel with the little Miller Maxstar 150 inverters, using the contractor case that miller sells as one option for that machine. A dynasty is too big to carry on, which pretty much means you're checking it. A pelican case is a good bet, I use one when I need to travel with welding or other gear I don't want smashed. Barring that, I'd pack it in two boxes, one nested inside the other with bubble wrap or packing peanuts filling the space between the boxes and around the dynasty. TSA will have their way with it, so I'd pack a roll of quality packing tape inside with a friendly note asking them to re-seal the box when they're done.When all else fails call your airline and ask them how to handle it. Or just get to the airport extra early....Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:Carry it in your underwear, then they'll be sure to miss it"Any day above ground is a good day"http://www.farmersamm.com/
Reply:So there I was in Dallas at a customer site and nothing really to do in the evening. Well, this guy was closing down his machine shop and had a 30a spoolgun. He claims mostly unused. By the tip, an older model, but still in great condition. Protective sleeve never put on the cables.So I bought it and put it in my suitcase....Got to Maryland and had a friendly TSA note that said they opened my suitcase and hand inspected it.Hand inspection only happens if they detect something suspicious. Bomb material (although the TSA has never actually found a real bomb, nor have they ever stopped a terrorist.....), Peanut butter, certain rubbers (wet suits), and certain magazines (the agent I talked to said women magazines, he assumes the perfume smelling stuff...) are almost automatic hand inspection. Why anyone packs peanut butter...Con Fuse!Miller Dynasty 350Millermatic 350P-Spoolmatic 30AMiller Multimatic 200Hypertherm PowerMax 1000G3Miller Maxstar 200DXYou probably don't wanna know on the peanut butter Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:It sounds like airport security is really lax in the US. You'd never get it on as a carry on in Canada. You can't even carry a toothpaste tube or water bottle over 100ml as carry on. I went to see my sister at Christmas in the the next province, 1:15 flight. My sister owns a salon and gave me gift pack of hair products for the GF who couldn't go. It had to be checked and couldn't go as carry on. I've even had to let them swab and check out a battery operated dump truck the last time I went. Even nail clippers are a no no as carry on. An electronic machine, forget it!
Reply:I know we've had customers buy a welder and use it as their carryon. I guess it depends. If you can store it in overhead, meet the weight and size restrictions and they can xray it and use their sniffers on it, they shouldn't have a problem, but who knows these days?Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT |
