Plasma cutter on welding rig
发表于 2021-8-31 22:45:33 | 显示全部楼层 |阅读模式
Hey guys, I was wondering if any of you have/use a plasma cutter on your welding rigs. I'm getting mine setup and I already have a torch setup, but plasma is a lot cheaper. I'm not using a flatbed truck like a lot of guys use, I'm just using a 6x12 enclosed trailer so none of my equipment will be stolen, plus it's a lot cheaper. I've decided that instead of a diesel drive welder, I'm using a high end generator and a multi process machine. Anyways, I just wanted to know how many of you might use plasma cutters on your welding rigs and if it's a good idea. Thanks in advance.
Reply:I have my PM 45 on my rig ...But it does have limitationsBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:I mean, I feel like you can use a torch for anything, but the plasma cutter can cut through thick stuff, consumables are cheapish, and usually produces nicer cuts. What are the drawbacks?
Reply:Just need to have enough aux power to run them, as well as air.
Reply:What plasma cutter? If we know that bit of info we can help you determine generator power consumption, air flow requirements and cut capacity. From there you can determine drawbacks/advantages.Jim Colt Originally Posted by MotoMan1500I mean, I feel like you can use a torch for anything, but the plasma cutter can cut through thick stuff, consumables are cheapish, and usually produces nicer cuts. What are the drawbacks?
GMT+8, 2025-12-29 20:42 , Processed in 0.097329 second(s), 18 queries .
