My slice of heaven
发表于 2021-8-31 22:45:32 | 显示全部楼层 |阅读模式
I just found out my phone takes panoramic pictures so I figured I would show off my little work area. The last bay in the shop is where I reside 5 days of the week! Attached ImagesLast edited by Burnt Glove; 01-21-2015 at 06:02 PM.
Reply:Might wanna try the Horizontal panoramic setting next time Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:That is... all of the stuff is bolted to the wall!I will try and fix it later.
Reply:Can't get it to rotate.  Oh well. Turn your monitor on its side!
Reply:Originally Posted by Burnt GloveCan't get it to rotate.  Oh well. Turn your monitor on its side!
Reply:Originally Posted by MikeGyverNope... if you don't even care why should we?
Reply:That's a big shed lol, nice one to.Ranger 250 thick stuffHobart Handler 140 not thick stuffthe pane and oxy setup
GMT+8, 2025-12-29 20:43 , Processed in 0.098171 second(s), 18 queries .
