hobart 210mvp running of harbor freight 7000 watt gen?
发表于 2021-8-31 22:45:32 | 显示全部楼层 |阅读模式
Would a harbor freight 7000 watt generator run a Hobart 210mvp or would I have issues?
Reply:Originally Posted by greener179Would a harbor freight 7000 watt generator run a Hobart 210mvp or would I have issues?
Reply:Originally Posted by BistineauYes???
Reply:Honestly- probably no issues. The biggest issue people have with running welding machines from genets is the size of the generator. Iffin' it is the Predator 7000/8250 peak genset then you are right at the matched size for the Hobart's needs in power.You'll need to make an adapter plug/pigtail since the Genset has a twist lock 240v 30amp receptacle.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by MinnesotaDaveHa!  Sounds like how I answer questions like "do you want pie or ice cream?""Yes."
Reply:Inverter machines can have issues with dirty power.  I assume transformer machines just need enough of whatever power.AHP AlphaTIG 200DX (2nd Gen)Lincoln WeldPak 3200HD Bird Poop GeneratorLotos LTP5000D Plasma Cutter
Reply:Is this the adapter I would need? Also sorry about the double question I must not have been paying attention when I typed that last night.
Reply:That one looks like an adapter for an RVEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:It was i thought maybe it was the same. Im just not really sure where I would get the pig tail adapter you mentioned I am no were near electrical inclined to wire up my own.
Reply:Originally Posted by greener179 Is this the adapter I would need? Also sorry about the double question I must not have been paying attention when I typed that last night.
Reply:Thanks for the help, I will find someone to do that as soon as I pick up the generator.
Reply:For what it's worth, I bought the "champion" brand of that generator from Costco for less than HF sells theirs. Might be worth checking out. Also comes with battery, wheel kit, and remote starter. I actually paid for a membership to Costco just to buy that generator. Also run a 210mvp off it, with no problems at all. Your best bet would be to make your own adapter. Very easy. You need a length of cord, at least 10ga with 2 wires and a ground, an L14-30 plug, and a 6-50 receptacle. You could have an electrician wire it for you. Buy a 25 or 50' cord so it can be used as an extension cord from your generator.
Reply:Thanks for the heads up on the generator! After looking it up it seems like a better deal I will pick one of those up instead.
GMT+8, 2025-12-29 20:43 , Processed in 0.093053 second(s), 18 queries .
