Tig CAbles and connector for Lincoln Square Wave 175??
发表于 2021-8-31 22:45:31 | 显示全部楼层 |阅读模式
I bought a Lincoln SW 175 used last year, but it came without the tig cable and torch and connectors. I have some torches and a hand switch, but to buy the other stuff is out of my reach. Also the stick cable connector that came with it is not the correct one and barely fits in the socket. So I have looked at various 3rd party connectors and cables and cannot figure out which one fits my Lincoln. So I need the correct connector for my stick cable, and a whole new set from the welder to the torch. Does anybody know what I need to get is called? And where to look for best prices?
Reply:50mm Dinse.       "Gas through Dinse" for the tig torch.   https://www.arc-zone.com/index.php?m...oducts_id=9089https://www.arc-zone.com/index.php?m...roducts_id=772https://www.arc-zone.com/index.php?m...oducts_id=9030
Reply:Originally Posted by Advan50mm Dinse.       "Gas through Dinse" for the tig torch.   https://www.arc-zone.com/index.php?m...oducts_id=9089https://www.arc-zone.com/index.php?m...roducts_id=772https://www.arc-zone.com/index.php?m...oducts_id=9030
GMT+8, 2025-12-29 20:41 , Processed in 0.099623 second(s), 18 queries .
