help where to buy
发表于 2021-8-31 22:45:29 | 显示全部楼层 |阅读模式
i saw this before and looking to buyone of these wel-bilt hyd. gear pullersi google it but found nothing have a big job to make half round railing for for balconys for condos Attached Images
Reply:no one has seen this on this site before
Reply:Our friends at harbor freight can help you...They have a relatively cheap one...Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Found a picture...A little different, but nearly the same. 59.99 or on sale sometimes for 49.99Here's the link: http://www.harborfreight.com/cpi/cta...112&zmap=95326 Attached ImagesEsab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:what are you going to use it to do?  i am confusedwww.burdettenetworks.com
Reply:Originally Posted by lugweldFound a picture...A little different, but nearly the same. 59.99 or on sale sometimes for 49.99
Reply:Oh yeah, Harbor Freight sells a variety of Hydraulic Gear Puller. Try looking for one at jabetc too.Midwest Metal ProductsMetal Wire Forming Fan Guards Delta-Larm
Reply:ed mac, please check your private messages. I'm looking for some info.Just my  opinion, not from a book, just from the road.Howes Welding Inc.www.howesweldinginc.com
Reply:Bump, ed are you there?Just my  opinion, not from a book, just from the road.Howes Welding Inc.www.howesweldinginc.com
Reply:all i have are the pics i want to make onecant find the jack Attached Images
Reply:ed, check your private messages. I can give you more info if you e-mail me. [email protected] my  opinion, not from a book, just from the road.Howes Welding Inc.www.howesweldinginc.com
Reply:Does anyone have one of these, and would you be willing to trace the end "hook", and fax it to me full size. Or perhaps dimension the part? Any help would be appreciated.Just my  opinion, not from a book, just from the road.Howes Welding Inc.www.howesweldinginc.com
Reply:http://www.northerntool.com/webapp/w...5912_200355912try that not sure if its the same kind you are looking for.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Not exactly, I have the hyd. jack lack) part of the unit. I am looking for dimensions or a tracing of the "hooks" on each end of the gray painted part.Just my  opinion, not from a book, just from the road.Howes Welding Inc.www.howesweldinginc.com
Reply:Where it says,"hyd. jack lack)"  it should read, "hyd. jack (black)"Just my  opinion, not from a book, just from the road.Howes Welding Inc.www.howesweldinginc.com
Reply:Would the hooks have to be forged, or of some type of tooll steel??  Don't know if mild steel would work"Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2025-12-29 20:41 , Processed in 0.104717 second(s), 18 queries .
