mig heavey plate
发表于 2021-8-31 22:45:23 | 显示全部楼层 |阅读模式
wiil some please infor me on steel 1" plate, such what wire and gas and cu.ft &. volts & polarity thanks
Reply:That could be anything, joint design and application dictate what wire and procedure is used. I have done 1" plate with .045 hard wire and CO2, dualshield, and self shielded wire. A little more info would be helpful.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Dual sheild flux cored .045 wire at 28 volts and start at 250 IPM. That's how I would weld 1 inch plate with a wire welder. It's not my first choice stick welding it is.Good luck and have fun !
Reply:Originally Posted by coreshield8wiil some please infor me on steel 1" plate, such what wire and gas and cu.ft &. volts & polarity thanks
Reply:I'll try to get more data. Thaks for you gus;s quick response.
Reply:I was working with some 3/4" Plate and I was using my Suitcase Welder, running Inner-Shield 5/64" wire around 30V & 380IPM.Just a Nice steady Drag Angle. DCENLast edited by DieselDon16; 06-18-2013 at 02:19 PM.Some Blue , Some Red & Some GreyProverbs 16:2-3.2 "All a person’s ways seem pure to them, but motives are weighed by the Lord. 3 Commit to the Lord whatever you do, and he will establish your plans."
Reply:1"....???      ..."Stick" it.  "Hey I didn't come to look and learn, I came to turn and burn.... If I can't light up, I'm gonna light out!"-JodyIdealarc 250 "Fatman"MM 252MM 211 "Little boy" Victor Torches
Reply:MIG short arc root and fill pass, then subarc with 1/8th wire 680 flux 35volts and 400amps at 18inp travle speed.
GMT+8, 2025-12-29 20:41 , Processed in 0.098772 second(s), 18 queries .
