Semi Conductor parts
发表于 2021-8-31 22:45:22 | 显示全部楼层 |阅读模式
Got started on a run of 5 Spiders today ........The last batch.....I used the old pulsar settings I used on my transformer machine which was 52 % on time 50 % background 2.5 PPSand 65 amps  ......Don't really think there is a better setting for these parts?  I might try a different set up for fusing the tubes (304)  I don't use any pulse when I fuse the butt joints but I may try something like 200 PPS and the default settings on "Back and On" with like 60 amps? the tubes are .030 wall stainless......Last edited by B_C; 06-18-2013 at 09:31 PM.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Good looking work as usual B_C.  Wish I could find one of those positioners for a good price.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Looks good as always BC.Question: Do you need to purge them and if so, is that a hassle when you use the positioner? Or does the configuration of that joint allow you to not worry about back purging?Looks like you get a lot of work out of Silicon Valley, eh?
Reply:Originally Posted by KelvinLooks good as always BC.Question: Do you need to purge them and if so, is that a hassle when you use the positioner? Or does the configuration of that joint allow you to not worry about back purging?Looks like you get a lot of work out of Silicon Valley, eh?
Reply:Very nice work! I have the same positioner, I love that thing. So handy when you need it. Some crazy nut from here let it go for next to nothing  I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by weldermikeSome crazy nut from here let it go for next to nothing
Reply:Originally Posted by ZTFabBreaker 1, Breaker 1, I might be crazy but I ain't dumb...Crazy Cooter comin' at ya!Nice work BC!
Reply:Got a late start this morning so I did all the parts that required the rotary and then welded up a couple on the fixture.....probably do the rest tomorrow....... I got a couple tubes a little hot but the insides looked fine....as long as they don't leak I'm good.....Last edited by B_C; 06-21-2013 at 11:13 PM.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
GMT+8, 2025-12-29 20:43 , Processed in 0.098828 second(s), 18 queries .
