Cut-o-matic by indiana oxygen company
发表于 2021-8-31 22:45:21 | 显示全部楼层 |阅读模式
I found a cutting machine that is stamped cut-o-matic, it has a plate that says Indiana oxygen company, indianapolis. Ind. There's another stamped that says: MFG'D BY INOXCO. I called the company and they said that it was used for torch cutting and they stopped making it in 1969 & parts are very hard to find so figured I'd put it up here to see if there was any interest?. It seems to have all the valves, knobs, switches, electical cord, seems to be totally complete. I can send out pic's if anyone is interested in it. I'm in NE GA and it weights about 50 lbs so its going to be alittle costly to ship. Thanks, Don ([email protected])ps: I did plug it in and I could hear a humming noise coming from it so I don't know if that's good or bad.Last edited by goldminer; 04-11-2008 at 03:15 PM.
Reply:I found a cutting machine that is stamped cut-o-matic, it has a plate that says Indiana oxygen company, indianapolis. Ind. There's another stamped that says: MFG'D BY INOXCO. I called the company and they said that it was used for torch cutting and they stopped making it in 1969 & parts are very hard to find so figured I'd put it up here to see if there was any interest?. It seems to have all the valves, knobs, switches, electical cord, seems to be totally complete. I'm in NE GA and it weights about 50 lbs so its going to be alittle costly to ship. Thanks, Don ([email protected])ps: I did plug it in and I could hear a humming noise coming from it so I don't know if that's good or bad. Attached Images
GMT+8, 2025-12-29 20:42 , Processed in 0.100226 second(s), 18 queries .
