Dog Crate
发表于 2021-8-31 22:45:17 | 显示全部楼层 |阅读模式
This is a Dog Crate I made for a bear hunter here in West Virginia.  I hadn't welded aluminum in about seven months, and it took me a while to get my sh*t together, but once I did, the gremlins came out.  Leaky water hose on my torch exploded in my face five times one night, I felt like I was auditioning for a Peter North film.  Once I got that fixed, the gas hose split, so I fixed it, and it split again.  Trouble was, it leaked just enough to make me think my skills were at fault.  The tungsten never discolored, but running a bead-on-plate showed very little etching at the toes, so I switched over to my air cooled torch and problem solved.  But welding at 190 amps AC on a 150 amp air cooled torch sucks, and a trip to my LWS was out of the question, so I got a $3 piece of 1/4" vinyl tubing, connected it to the barb fitting with some electrical tape and I was back in business.  My work is nowhere near the level of ZTfab or some of the other heavy hitters here, but I am pleased.  Aluminum: It's not that it's harder to weld, it's just sooo much easier to screw it up. Attached ImagesLast edited by bebo; 10-01-2013 at 03:22 PM.
Reply:Yo man very nice set up for the hunting pooches! You did a great job bud! I was expecting to see some 1/8 wire tacked together in a box after reading the title. Nice job! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Nicely done Thumbs up for being able to work through that many problems - I'd have been going nuts!!Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Aluminum: It's not that it's harder to weld, it's just sooo much easier to screw it up.
Reply:Originally Posted by WenValleyNice work, really like your quote, it's so true.  When I saw the photo I thought, "damn, they sure have short pickup trucks down there"....  Then I noticed that it's for a utility vehicle....
Reply:looks great!, in the last pick I would have welded from the outside in. makes for less material to heat up upon initiation of weld, and more heat built up when you get to the conjoining of joints where you need more heat to get full penetration.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Why the funny mitred corners instead of just going straight down ?
Reply:Originally Posted by turklooks great!, in the last pick I would have welded from the outside in. makes for less material to heat up upon initiation of weld, and more heat built up when you get to the conjoining of joints where you need more heat to get full penetration.
Reply:Regarding the mitered corners, It's what the client wanted.
Reply:Lol @ the Peter North reference.  I was thinking that before I even read it.  Hahahahha-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:looks great
Reply:Originally Posted by rabidchimpLol @ the Peter North reference.  I was thinking that before I even read it.  Hahahahha-Aaron
Reply:Some of us have seen the videos and been around long enough to remember some of these performers.
Reply:Nice work.I do a lot of bits and bobs for the Rangers. Here's a canopy.JF
Reply:And a crateNot meant to hijack. Just noticed the bed. And an XP to boot. Only had one over here so far, didn't like it if I'm honest.JF Attached Images
Reply:Nice Job, what are the circular tubes/cylinders on the sides panels??
Reply:The cylinders are alignment tubes I made on the lathe to get everything lined up with the bed of the polaris.  They just pull out and the crate gets attached using expandable rubber plugs
Reply:bits and bobs?...diesel Ranger?....are you in the UK?  Nice looking accessories
Reply:Peter North reference, HILARIOUS!!! That's as bad as Grandma - "I love Sudoku, so I'm sure I will love this new game Bukake!" Awesome dog crates btw, sweet work!!Lincoln Weldanpower AC/DCLincoln LN-25Miller WC-115a Miller Spoolmatic 30aCheck out my youtube TV Channel
GMT+8, 2025-12-29 20:44 , Processed in 0.100893 second(s), 18 queries .
