Flap Discs go over 120 Grit.........
发表于 2021-8-31 22:45:16 | 显示全部楼层 |阅读模式
Since I started learning how to polish Stainless Steel for Dominoes....... I was only able to find up to 120 Grit Flappers for my angle Grinder........My other choice to get finer grit.... before going to buff..... was to spend a BUNCH of money on different equipment to get a finer grit.......Well..... McMaster Carr is my crack addiction....... I have found up to 600 grit flappers......... for my angle grinders........They are stated to be for non-metals..... but..... i'm going to try them on stainless..... 220.... 320..... 400..... 600..... then.... buff with green....PICS...... Attached ImagesPrecision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:The number in the box isn't the price is it? In granite work I use polishing pads from 50 to 3500 grit ( sparkley ) I have messed around a little on metal does work.. A set of pads and a backer that fits your grinder and a router speed controller from HF would run ya under 250.00 . Gran quarts often has deals on their close outs page.
Reply:I'm not sure what the number in the box is......Even with a $30 blade for the bandsaw.... The total order was $70 before shipping........ So even if they burn off real fast...... It's worth the expense to try......Mick..... I'll look at Trizact....... Thanks for the tip.........Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:After i finish with the flap disc work, I use the 3" and 2" roloc fiber discs for my finer polishing and finishing with great results.  I have not used them on stainless but I dont know why they would not work.   I purchase mine thru enco.
Reply:OH MAN ! I'm sorry I called your filler holder chit( but I was right ).Thank you. THANK YOU ! I do a lot of polishing work too and have been stuck at 120 and then heading to the buffer ! Attached ImagesBubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:I use this on some of the flatter pieces that i Polish (mostly aluminum), mounted to either my bench grinder or polishing machinehttp://www.caswellplating.com/buffin...-6-x-1-25.html
Reply:+1 on the Roloc discs. The 3M Scotchbrite discs come in coarse, medium, and fine and are available with stiff or flexible backing. I mostly use them on silicon bronze but they work well on stainless as well. They leave a very nice finish.Those silicon carbide flap discs for "non-metals" are also recommended for copper alloys and cast iron. They work on steel and stainless but do not last as long as aluminum oxide discs.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:Quit buying your blades from Mcmaster.http://www.use-enco.com/CGI/INSRIT?PMAKA=240-4930I've got them for as low as $10 on sale.My name's not Jim....
Reply:Holy crap batman.........Do the blades last a good bit firm Enco?Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:They last as long as anything unless you abuse them.  The Irwin Bi-metal blades are all I buy.My name's not Jim....
Reply:Originally Posted by BurpeeOH MAN ! I'm sorry I called your filler holder chit( but I was right ).Thank you. THANK YOU ! I do a lot of polishing work too and have been stuck at 120 and then heading to the buffer !
GMT+8, 2025-12-29 20:42 , Processed in 0.099044 second(s), 18 queries .
