I have a chance to buy a thermal arc fabricator 130 for $200.00 and I was wondering if this is a good deal? I understand all of the limitations of a 115v welder but I am a home user and will be doing mostly auto sheet metal and up to 11 gauge or so building a squat rack. I have read that most home gym equipment is built from 11 gauge square tube. Before anyone comments, I am not a pro welder but I do understand cold welds, penetration/fusion, single/multi pass, preheating, duty cycle, etc. I will be using GMAW on the sheet and FCAW on the heavier stuff and I weld currently as a hobbyist. I also understand that a 230v welder is always preferred but I don't want to invest that much in a home welder that will see very light usage.Is this a good machine? Is the price fair given the age of the model?How thick could I reliably weld with preheating and/or multi-pass? Thank you
Reply:If you can test it out before buying, and it works to your satisfaction, I'd say it's a good value.Does if come with a gun, ground and regulator?Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Its probably a fair price but 130 amps is not much. 11 gauge is probably the very upper limit for this machine.Miller Multimatic 255
Reply:I believe its a made in Italy machine and the gun has a brass back end. Much better than the other ones that came out of the same factory. If it works it's good.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by AKweldshopIf you can test it out before buying, and it works to your satisfaction, I'd say it's a good value.Does if come with a gun, ground and regulator?
Reply:Thanks for the replies. Would you all say that it is comparable to a lincoln SP-135 and hobart handler 140?
Reply:Ya about there. The hobart is about the 3rd best 110v machine you can buy in my opinion. HTP 140 and snap on fm140 are the only other two that I would say are better and probably the most power that can be had from a 110v mig.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Thanks again everyone. I will be picking it up this week.
Reply:I would go with the lincoln 210 mp. It's worth the few hundred more.
Reply:A few hundred more? its 5 times more. You are talking $200 bucks vs a grand. Not even the same zip code.Miller Multimatic 255
Reply:Oops. I got confused with another thread. Working late and being up to late weary hours is to blame. For $200 seems like a good deal.
Reply:Thanks |
