Correct part number for Lenco...
发表于 2021-8-31 22:45:08 | 显示全部楼层 |阅读模式
I am looking for the correct part number for the Lenco connector used on the Syncro 200 TIG torch....I have my old one but there is no number on it...I bought a new CK Flex Loc and would rather not switch the connector from old to new torch, may want to use it again later.Retired - "Her job is to Bitch - mine is to give her a reason"Miller Syncro 200Miller 211 AutoSetMiller 375 ExtremeAn old Ox/Acc
Reply:When I get home I can look it up in my catalog if no one beats me to it.
Reply:According to the catalog I have that is the Profax/Lenco Cat. that is you number.  here is what it looks likeLDP-50MLDTI-26-RThis last one is rated at 200 ampsLast edited by Scott Young; 06-25-2013 at 11:10 PM.
Reply:here is the water cooler connection.LDTI-1820-WC
Reply:Scott - the LDP-50M would be for the work lead as it isn't a feed-thru for the TIG torch shielding gas.This catalog page lists which various connectors fit the different machines including the OP's Syncrowave 200http://profaxlenco.com/images/Catalo...achinePlug.pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Yeah I just could scan my catalog page. Thanks for clearing that up.
Reply:Originally Posted by duaneb55Scott - the LDP-50M would be for the work lead as it isn't a feed-thru for the TIG torch shielding gas.This catalog page lists which various connectors fit the different machines including the OP's Syncrowave 200http://profaxlenco.com/images/Catalo...achinePlug.pdf
GMT+8, 2025-12-29 20:42 , Processed in 0.093924 second(s), 18 queries .
