Hypertherm 45 vs used 600?
发表于 2021-8-31 22:45:04 | 显示全部楼层 |阅读模式
I am in the market for a plasma cutter. Considering a Hypertherm 45 or a used 600. Are there any performance differences between the two that would make a noticeable difference? I expect a good used 600 would cost about half what a 45 goes for. It will see hobbyist use.Bob.Miller Dynasty 200 DXMillermatic 211Hypertherm PM 600In Tool acquisition Mode
Reply:Nicad,I suggest you PM Jim Colt from Hypertherm for the very best answer you can get and you may wish to post your question in the Hypertherm running thread as well.DuaneMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Good tip, thanks, DuaneBob.Bob.Miller Dynasty 200 DXMillermatic 211Hypertherm PM 600In Tool acquisition Mode
Reply:Nicad,I responded to your PM as well. The Powermax45 is the replacement for the 600. Hypertherm sold over 55,000 600's......and they are a great system. Why replace it? The 45 is lighter, more reliable, has a torch with better visibility, cuts faster, cuts thicker, has higher duty cycle and longer consumable life. I may have missed a couple of things!That being said....the Powermax600 is a great machine.....and there have to be quite a few on the used market. It can use Hypertherm's FineCut consumables for excellent quality on materials thinner than 3/16".....and can cut thicker than it is advertised for. Hypertherm will support the 600 for many years with parts and free tech support. If you can get a 600 for a decent price...and it fits in your cutting thickness range....it's usually a good buy! The operators manual for the 600 can be downloaded from the www.hypertherm.com  web site....look for the library tab at the top of the home page.Jim Colt
Reply:Thanks Jim, it is great that you are here sharing your expertise on Plasma and your brand.Bob.Miller Dynasty 200 DXMillermatic 211Hypertherm PM 600In Tool acquisition Mode
Reply:For hobby work the 600 with the newer fine cut consumables is hard to beat. If you can pick the 600 for a good price I would certainly go for it.Their a great investmentCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
GMT+8, 2025-12-29 22:14 , Processed in 0.101715 second(s), 18 queries .
