FS: Miller 22A Wire Feeder
发表于 2021-8-31 22:45:03 | 显示全部楼层 |阅读模式
used, unit came from a large manufacturers maintenance department.unit works well and is a 6-7 out of 10 in appearance.No gun with unit , and the switch that toggles the trigger function from normal to continuous is broken off , switch still functions and can be manipulated with gloves on. ( i don't know any one who uses this function. )I have the unit on Ebay as well400 plus shipping Attached Imagesinsert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:oh and the miller label on the other side is faded real good where it was wiped with brake cleaner dohinsert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
GMT+8, 2025-12-30 00:02 , Processed in 0.062261 second(s), 18 queries .
