Receiver and winch mount
发表于 2021-8-31 22:45:00 | 显示全部楼层 |阅读模式
Here is a receiver mount that I made, cost about 50 bucks and then I made a mount for a HF winch. Could have done some things differently; just always trying to improve.Thermal Arc 211iThermal Arc 201iThermal Arc 95SEverlast 200DXEverlast Powerplasma 50Victor OAVictor portatorch
Reply:Thermal Arc 211iThermal Arc 201iThermal Arc 95SEverlast 200DXEverlast Powerplasma 50Victor OAVictor portatorch
Reply:Attachment 512041512051[/attach] Attached ImagesThermal Arc 211iThermal Arc 201iThermal Arc 95SEverlast 200DXEverlast Powerplasma 50Victor OAVictor portatorch
Reply:Nice looking work,should do the job when needed.Joe
Reply:I like it. I might have to make one like that.  Then I can use in front, back or on the trailers.Carlohttp://public.fotki.com/Naudi2U/
Reply:I think that I hit everywhere I was welding with a wire wheel or a grinder before I welded it, although i could be wrong and I took some of the pictures out of order, so they may not reflect that. In any case you're right I should have done better with prep on the winch mount, prolly not a bad idea if I got a sandblaster in the future. I was much more meticulous with prep on the welded areas on the receiver that I bolted on the truck. Thanks for your input, though, because I'm always trying to find ways to improve Thermal Arc 211iThermal Arc 201iThermal Arc 95SEverlast 200DXEverlast Powerplasma 50Victor OAVictor portatorch
GMT+8, 2025-12-29 22:15 , Processed in 0.099673 second(s), 18 queries .
