This weekend I decided I needed to get my filler into position so I could access it easier.......I opted for a wall hang solution and decided to take a couple pics of the result......Ava helped....... by playing on the I-pad and letting me make lots of noise..... and she made sure I protected her ears and eyes before any drilling could start..........Good times......PICS...... Attached ImagesPrecision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Nice Job. I have open ended pvc tubes sitting on a shelf and they seem to roll off by themselves.TOO MANY TOOLS & NO MORE SPACE
Reply:Nice job! I really really need to redo my filler organization deal some day. I want plastic tubes on the sid eof the welder like the steel ones I have now but I need more of them and bigger.
Reply:Sure, but when someone decides to do chin-ups off that death trap and breaks the plastic brackets don't come crying back here. Next time use kindorf for the verticals and steel pipe clamps.
Reply:Originally Posted by rlitmanSure, but when someone decides to do chin-ups off that death trap and breaks the plastic brackets don't come crying back here. Next time use kindorf for the verticals and steel pipe clamps.
Reply:Looks neat and tidy. If you're like many others, you''ll need one of those for each metal group in short order, because there are so many specialized fillers for each kind and different sizes too...
Reply:.045", 1/16 and 3/32 in 70s-2, 308L and 5356 is nine slots already, add a 309 and 4043 and you'll need a bit bigger wall, but you do have room for a few additional tubes. Are you using RG45 for gas, or low fuming bronze?SqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:I have only RG45...... But I use gas so little that I use that tube for overflow aluminum filler more than anything........Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:You guys are way too nice to be welders ?It looks like chit ! You should have spent an extra 75 cents for PVC and used a sharpie.If you would have used metal hooks you could lift the m/frz out to retrieve shorts. Have a nice fu#$%@!! day. Nice tape. Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Originally Posted by MondoI thought that was a ladder to the attic hatch!
Reply:Originally Posted by DSWI keep trying to figure out what all that blank white stuff is behind the rack is. There's nothing like that in my garage! If it's not a window ( and even 2 of those are covered over), or a door ( man door is only partially blocked), it's covered in shelves full of "stuff".
Reply:nice fexal here is what i use for filler storage but i also have a ton more filler to keep track off Miller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Holy cut length Tig Man! What a rack(of filler)I like yours too Fexal.
Reply:Nice filler storage Wookie, seems totally reasonable.SqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:For a home /garage shop, it's perfect Sean! keep junk off the floor as much as possible!I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Damn it you guys!
Reply:Hi, I've been lurking around for months now but.. Here's my first post.I just made a table so I can teach myself to tig weld. You can see my filler storage I came up with.Robert
Reply:Nice bench, I'd keep that filler inside something though, it'll get dusty at best, and greasy at worst.SqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:Yup, then oxidized, and rusty, and some other nasty stuff that won't come off and contaminate every weld you ever try to make.
Reply:they are in clear plastic tubesDynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:So they are, sorry.SqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:I blame Brazin, he told me to say something.
Reply:Hey, Fex.Here's a little roll-around cart I built to keep my filler rods. It is made out of scrap I had in the shop and works good.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:Originally Posted by VPTI blame Brazin, he told me to say something.No need to defend yourself for giving someone some advice who said their going to teach them self to tig weld!The scrap from building the table felt perfict to make some filler holder's. Even if it holds a few lbs. it was just a good use of scrapRobert
Reply:...So how's that TIG going Rob? Almost ready for your photo analysis/abuse thread? I hope you're putting that sweet bench to work. SqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:Originally Posted by wb4rtHey, Fex.Here's a little roll-around cart I built to keep my filler rods. It is made out of scrap I had in the shop and works good.
Reply:Here is how I store mine.4043 on one side. 5356 on the other. I spray one end of the 1/16" 5356 black to tell them apart. Odds and ends steel and brazing rods in the back. The REAL important stuff I keep locked up so idiots dont use them to make paint project hangers. If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:Nice . ANY organization is better then none. That is gonna make a difference.Boy, AVA is really growing. She will be going to college before you know it. Enjoy the time with her AND make the time to be with her.
Reply:Bd...... We have great fun together...... She loves her tools and working in the yard.........The only time we don't see eye to eye is bedtime........... Mommy has to step in..... Going on 2 months now....... My fuse and her fuse is super short....... Only the wife can chill us out.......It must be an Irish thing...... It takes the Polock to chill me and Ava out.......Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/ |
