AC Pulse on Invertig 221
发表于 2021-8-31 22:44:51 | 显示全部楼层 |阅读模式
I've been watching Jody's videos on YouTube and he mentions using pulse where thinner metal is involved.I bought the welder to make parts for my airplane (Vans RV-7A), we're talking mainly .040 5052 AL fillet and corner joints. Yes, I know that as a noobie, thin wall AL welds are some of the toughest, but I'm going thru bottles of gas and my welds are better and the "blown away" parts are less - but I'm looking suggestions. Note, I've not actually put ANY of my "welded parts" on the aircraft yet, I know my limitations here.Jody's "rule of 33" does not appear to apply to AC welding on the Invertig, since the AC Pulse Frequency can only go to 10Hz in AC, Does using 1-2Hz in AC do the same job as 33Hz?Perhaps for thin AL there are some suggestions for the Invertig Electrode Negative and/or Electrode Positive settings?
Reply:.............Last edited by Drf255; 07-07-2013 at 05:49 AM.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:It does 10 pulses per second on AC. So no you can't do 33, but 10 works well.DC pulse goes to 999. Find a setting that works for you, just because Jody says it doesn't mean you have to do it.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Hmmmmm I have better results with smaller front end parts and normal AC.....Might be wrong but haven't experienced the benefit of pulse on AC....Watching the puddle and dabing as necessary works for me.....There is no magic settings for thin aluminum, either you understand how to weld it or Not......  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
GMT+8, 2025-12-29 22:13 , Processed in 0.117670 second(s), 18 queries .
