Good mig for new welder
发表于 2021-8-31 22:44:51 | 显示全部楼层 |阅读模式
Looking to pick up a new skill, narrowed down to Lincoln 180s but came across this. Just looking for some opinions. Looks like an older welder but a Miller.http://calgary.kijiji.ca/c-buy-and-s...AdIdZ500586118Last edited by djfob; 07-04-2013 at 01:39 AM.
Reply:Originally Posted by djfobLooking to pick up a new skill, narrowed down to Lincoln 180s but came across this. Just looking for some opinions. Looks like an older welder but a Miller.http://calgary.kijiji.ca/c-buy-and-s...AdIdZ500586118
Reply:Doesn't look it has been well cared for but he says its in working order. What year was the unit manufactured?
Reply:You'd need the SN to tell that.  It's on the front of the machine.  Miller made them for years.  My understanding is that when Miller came out with the 250, people didn't like the arc compared with the old 200.  So they made the vintage.  This is what I've read.If it works, buy it and you will be very happy.  You won't find a person here that will say a bad thing about that machineLast edited by Drf255; 07-04-2013 at 05:32 AM.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:The Miller 200 has always been rated very highly. A friend has one that he bought when they first came out, maybe 20 years ago and it's still working perfectly with no break downs. The machine in the pictures is rather dirty, I'd have to look at it in person and run a bead or two before buying a used machine, in any case. That may or may not be possible in an auction setting. The price is not bad compared to the Miller 250 series which it the successor to the 200. The 211 and 212 are a different configuration. although they are a good unit as well.
Reply:I've used two of them (millermatic 200) - liked them both Dave J.Last edited by MinnesotaDave; 07-04-2013 at 12:46 PM.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Just to mention, Miller REBATE program is still active.  5 to 15 % rebate.http://www.millerwelds.com/landing/build-with-blue/
Reply:The unit can't be tested as the don't have a power source, that kinda sours the deal. He is willing to sell for $400.
Reply:Open the machine.  Look for leaking capacitors.  There's a bank of them on the left side of the machine (as you stand behind it) near the back.The motor is robust and pretty much never fails.  It's a transformer machine. Look for any burns on the very few boards it has.  Look that all the drive roller parts are there.  Check the input jumper is in the right place.Offer the guy $250 explaining that you can't test it, nor can any other buyer.  You can get alot of help here refurbishing it. Duaneb55 is the resident expert.Here's a look at mine.  I bought it for $299 including the spot panel and a Spoolmatic 1. There was zero wrong with the machine, and the Spoolmatic needed one wire soldered in the plug.http://weldingweb.com/vbb/showthread.php...ght=Mm200+redohttp://weldingweb.com/vbb/showthread.php...ght=Mm200+redoLast edited by Drf255; 07-05-2013 at 05:15 AM.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Buy the biggest one you can afford. Trust me
GMT+8, 2025-12-29 22:32 , Processed in 0.101922 second(s), 18 queries .
