Lincoln MIG PAK 15 ......Gun and Cable????
发表于 2021-8-31 22:44:45 | 显示全部楼层 |阅读模式
Hi...I need a new gun and cable for my Mig Pak 15,,,What is the most economical ???What aftermarket gun will work?Thanks In advanced...
Reply:You probably won't beat the price on the factory replacement. To find out if any others make one that will fit you need to ID the existing gun. It looks like a Magnum 100 to me, but the pic I have isn't very good. Your owners manual should tell you which gun it uses. Once you know that you simply check other manufacturers to see if they make a replacement. Then find someone who sells it and check the price.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:Thanks Again  Jolly Roger..your right it is a Magnum 100 gun.....what manufacturers would you suggest?
Reply:I have a bernard gun for my sp175plus and I love it. It is a Q gun with centerfire consumables. I still have my mag 100 sitting around the shop but will never use it again.Guy_48Welding is an art......Millermatic 252Lincoln SP175PlusLincoln 225 AC/DC
Reply:Sounds good...what would you like for it.Thanks Ken
GMT+8, 2025-12-29 22:32 , Processed in 0.099719 second(s), 18 queries .
