How much?
发表于 2021-8-31 22:44:42 | 显示全部楼层 |阅读模式
I have a oxy/acetylene torch set with victor sr 460a & sr 450d gauges and cutting torch, I believe the tanks are around 80 cf, both are about 6-7" dia. and the oxygen is 4' tall while the acetylene is 3'.  It's all on a cart as well. Works just fineI also have an old Marquette instant arc buzz box with roughly 50' of cable on it and have no idea what it's worth. I have to assume it works knowing the previous owner was very meticulous. I inherited it all with good intentions about 4yrs ago and nothing has transpired since so it's time to let em go.Any ideas on prices would be grealy appreciated.
Reply:How about a location the items are at? That helps and also pics.
Reply:Sorry I forgot about that.  I'm in northern Michigan.  I also have a Delta Horizontal bandsaw to part with.  Thanks again
Reply:Hey Sewerjockey,I say $250-$400 for the torch set, $150 for the mini band saw. Neat buzz box. Find the right buyer, and it is probably worth more as an antique, than as a welder. I put it at $150 becauseit looks to have a lot of lead with it.Maybe someone else may have another opinion.Good Luck
Reply:if you want to let the torch set go I would be interested I live by Ann Arbor so I don't think your to far?
GMT+8, 2025-12-29 22:31 , Processed in 0.096693 second(s), 18 queries .
