One Man's Junk
发表于 2021-8-31 22:44:41 | 显示全部楼层 |阅读模式
Scored this for free today, all 300+ lbs. It will make a fine Saguaro Cactus. Question is, what was it in it's first life? There is a ton of thick heavy rust on it leading me to believe it was in salt water, or else someone chemically treated it to speed up the rust. Was it a cooler for a marine engine, or for a generating plant?Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:Maybe cooling fins for a pipeline?
Reply:bigbThis Gorgeous-Chattel obviously has had a past life   -   do you have any idea of its original life?Opus
Reply:Originally Posted by OPUS FERRObigbThis Gorgeous-Chattel obviously has had a past life   -   do you have any idea of its original life?Opus
Reply:Looks like a crowned drive roller for a belt conveyor.
Reply:bigbM J D may take the prize:After an appelit review of your photo's, it appears your Saguaro is double tapered.Opus
Reply:Looks like some of the things I have seen in fertilizer handling places. That one has deffinatly seen better days.
Reply:if it was used in fertilizer stuff that would explain the corrosion.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
GMT+8, 2025-12-29 22:31 , Processed in 0.073812 second(s), 18 queries .
