Hobart 210 Cart
发表于 2021-8-31 22:44:40 | 显示全部楼层 |阅读模式
Here's a little cart I've been working on for my hobart 210. It's still a work in progress, as I still need to figure out a better way to organize my cables. All the metal that was used, was scrap, from either work or school. The handle on the front, and the bent tube between the welder and tank were both projects for school last semester. If you have any suggestions or comments for my cart, please share them!
Reply:Cute little buckaroo! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:It's nice...I'd add another caster on the front. Doesn't it get kinda "tippy"? I like the red wheels also.Miller Syncrowave 180Miller 211 w/ spool-gunLincoln Ac/Dc buzzboxCutmaster 38 plasmaVictor,Smith's,and Craftsman (Harris) O/A torches.DeWalt Multi cutterFiber Metal helmets(old school)Enough Snap-On to be a dealer
Reply:That little clear caster is just too cute!  And probably not long for this world!
Reply:it's actually fairly stable, having the cylinder in back puts most of the weight over the pnuematic wheels. i was worried about it being tippy as well, the rear wheels are fairly far apart, giving it a decent amount of stability. i picked the clear caster because its a locking caster.
Reply:This may be a option for tidying up the cables / gun , i fabed this up quick for a work machine.. Briggs weldnpower 225/210/cvLn-25 suitcaseMillermatic 130
Reply:How tall are you? Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Really neat!Definitly add a cable organizer/rest. I used a cast-off garden hose holder.But 1/2 a riding mower wheel will do nicely as well.Be wary of The Numbers: Figures don't lie,. but liars can figure.Welders:2008 Lincoln 140 GMAW&FCAW2012 HF 165 'toy' GTAW&SMAW1970's Cobbled together O/A
Reply:Originally Posted by Broccoli1How tall are you?
Reply:Cute as a button! Something that I might do is make a longer wagon style handle that would stow away under the cart. Drop the handle to the horizontal and push it straight back into a pipe... maybe. Really like the tire/HOBART color match, too! POVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:Looks like all his welding is on the floor so the height works Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:You can't get much welding time with such a small tank. What happens if you get a bigger tank? Weld On!
Reply:I would finish welding then turn around and trip over it Good job on the cart.
Reply:Most of my welding is done on the ground, so it works out nicely. I've considered adding a taller handle, one that goes over the top of the machine. I'll most likely end up using the tube bender at school to make something. I like the cable holder for the Millermatic 180 that Winmac posted, I'll look into creating something like that.
Reply:Cute little sucker. When it grows up is it gonna have a MILLER on it ?
Reply:After a week or two of back aches from bending over to drag that thing you go ahead and make a taller one.
Reply:Originally Posted by BD1Cute little sucker. When it grows up is it gonna have a MILLER on it ?
Reply:Looks good!  I'm on here lurking tonight before I start on my cart for my new 210 also.
Reply:Here is the sketch up of my cart. And here is the cart in progress.  Still have a ways to go but its looking ok.  What do you guys think of the design?
GMT+8, 2025-12-29 22:32 , Processed in 0.095671 second(s), 18 queries .
