A little Fixture Making
发表于 2021-8-31 22:44:38 | 显示全部楼层 |阅读模式
Well I definitely do not get to weld as much as I would like to and I recently had a chance to make a fixture and weld it so I thought I'd share a couple photos see what you guys think.  I can definitely use more arc time so I take it when I can. Miller syncrowave 350lx. Set at 250 amps, 15/20 ish cfh argon, 1/16" ER70S2, 3/32" Ceriated. The ring is  1 1/8". Spokes are 3/4" Attached ImagesMillermatic 135Craftsman 7 Hp 80 Gallon           2 stage compressor
Reply:Good job bud! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Looks good. Heavy duty. What does it fixture? Do you have any photos of the fixture in use?
Reply:No In use pictures it's not actually complete just yet still need some more milling and a couple holes and once it moves on to the next department I probably won't see it again. It's for a gas turbine engine bearing housing.http://www.geaviation.com/engines/marine/lm2500.htmlJust a small piece for one of thoseLast edited by 70Challenger; 10-19-2013 at 12:05 PM.Millermatic 135Craftsman 7 Hp 80 Gallon           2 stage compressor
GMT+8, 2025-12-29 22:33 , Processed in 0.103387 second(s), 18 queries .
