Gas for Miller 350P
发表于 2021-8-31 22:44:37 | 显示全部楼层 |阅读模式
I just upgraded from a MM211 to a 350P.  I know there are different methods of welding this machine can do.  I currently have 75/25 for my MM211.  What gas do the different welding modes need on the 350P?  At this point I am only welding mild steel.  At some point I would like to get a Dynasty 280 so I know I will need a different gas for that as well.
Reply:Originally Posted by danmcphI just upgraded from a MM211 to a 350P.  I know there are different methods of welding this machine can do.  I currently have 75/25 for my MM211.  What gas do the different welding modes need on the 350P?  At this point I am only welding mild steel.  At some point I would like to get a Dynasty 280 so I know I will need a different gas for that as well.
Reply:For TIG you will need straight Argon. The pulse modes on the 350P are optimized for 90/10 but will work OK with anything from 5 to 15% CO2.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:I didn't get the push pull gun. How big a diff does the 90/10 gas make for pulse?Is it worth having 2 different bottles?Does 90/10 work for non pulse?
Reply:I have a 350P and Yes 90-10 makes a difference on pulse. B.J.
GMT+8, 2025-12-29 22:33 , Processed in 0.072191 second(s), 18 queries .
