How to get spray paint off
发表于 2021-8-31 22:44:35 | 显示全部楼层 |阅读模式
I was spray painting a project and the paint "dust" n the air landed on my prescription glasses and dried on them and i just noticed it. How do i get it off of them?Miller Dialarc 250Miller Bobcat 225Hobart Oxy/FuelCouple of Dewalt and Milwaukee GrindersJET Bandsaw and Drill Press
Reply:Acetone will take it right off. It won't harm plastic or glass lenses but can be hard on plastic frames as they are not chemical resistant. It's what I"ve used for years.SlobPurveyor of intimate unparalleled knowledge of nothing about everything.Oh yeah, also an unabashed internet "Troll" too.....
Reply:Are they glass or poly lenses? I'd probably use clay bar detailer in either case.
Reply:I've done that - if I recall, I used WD-40 and a clean rag since it was sitting right there when I noticed it.Probably safer to bring them to the glasses lady and have her clean it though.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by Gus_MahnAre they glass or poly lenses? I'd probably use clay bar detailer in either case.
Reply:My glasses place uses acetone to clean my glasses all the time, and that is what I use.Measure with a micrometre, mark with chalk,  cut with a torch.Never force anything...just get a bigger hammer.RoyOld Airco buzz box approx 1974Lincoln mig pack 15Lincoln 175 square wave1954 9" south bend lathe
Reply:My glasses place used Pledge furniture polish to clean lens on all the glasses they mfgd. It works great for cleaning most stuff off and leaves a coating that makes it easier to remove anything else that gets on the lens later. I use it it least twice a week and then just use t shirt to clean between times.
GMT+8, 2025-12-29 22:31 , Processed in 0.074825 second(s), 18 queries .
