HDPE welding
发表于 2021-8-31 22:44:35 | 显示全部楼层 |阅读模式
Needing to put an extension onto the mouth of an 1100 gal. tank using a 55 gal. barrel. Wondering where the best buy on a few rods might be, plus wondering if there'd be any reason I couldn't cut strips out of 5 gal. buckets for this.
Reply:I used Urethane Supply Co for all my filler material for plastic bumper repair when I did auto body. The pricing on their filler rid is very reasonable, and I'm sure you'll find using a uniform filler rod much easier than using strips of bucket. http:// http://www.urethanesupply.com/HDPE-1/
Reply:I use  http://www.usplastic.com/search/?q=welding&view=g   prices are pretty goodTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Not really applicable, but U.S. plastic rod suppliers are pricey for us Canucks.  I deal with these guys in the U.K., they ship worldwide, and cheaper than any U.S. supplier I contacted:http://www.plasticsolutionsuk.com/
Reply:Also string trimmer line works good on some repairs.  Pretty sure most of it is HDPE.  Bear in mind that not all plastics are equal, you have to know what you are welding and use the same type of rod.
Reply:Can you show a picture of what you have and what you want to do?I work with HDPE and I also work with plastic tanks and constructing assemblies using both.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:I have tried to weld HDPE and just get a charred, sunken, overheated mess with no strength. If anyone has good instructional material let me know! I am using a top of the line seely hot air welder with HDPE rod from urethane supply.  I have watched Utube video's, but I still can't get it.Last edited by blackbart; 02-02-2015 at 09:25 PM.
Reply:you have to clean both what you are welding and the hdpe strip, it gets a coating on it like almost no stick..Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:We used to weld little plastic soldiers together by lighting an old detergent bottle on fire and dripping it on them.  It sounded like VOOP, VOOP, VOOP if you held it high enough as you dripped it on them.  Got good fusion, especially if you got some on your hand or arm.  Many a kid still wears those badges.Kidding aside, I believe HDPE welding requires substantial pressure to effect a weld.  Think forge welding, not melting a couple candles together.  Heat AND pressure.Last edited by Oldendum; 02-02-2015 at 10:36 PM."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by roadkillbobbyou have to clean both what you are welding and the hdpe strip, it gets a coating on it like almost no stick..
GMT+8, 2025-12-29 22:33 , Processed in 0.115167 second(s), 18 queries .
