Grinding suggestions.......
发表于 2021-8-31 22:44:28 | 显示全部楼层 |阅读模式
I am building an "Asian" inspired piece of furniture and decided to build a quick and dirty practice piece to help me identify any problems that I may run into during the actual project. I am VERY new to metal working and my plan worked perfectly........I have identified a problem. I need to know what is the best type of grinding tool I can purchase to reshape my "inside corner welds" to a smooth finish. I can handle the outside corners and flat surfaces......but I have nothing small enough to fit inside the pieces I'll be building. I have included a photo so you can see my practice piece. Attached Images
Reply:a die grinder with a carbide bit?  or a dremel tool ,  rat tail file,  sand cloth on a dowl daye
Reply:I tried the dremmel tool..........it was pretty slow and it heated up pretty quickly. I'll have about 40 inside welds to clean up. I'll look into the other options......Thanks!!!!!!!Timmer
Reply:I think you could fit a 4 1/2" grinder in there with a cutting disc on it. The thinness of the cutting disc makes it work well for inside corners.Also you can get sanders that are built on a grinder body that have an extended arm about 10" long with the roller and platen on it. The belts are only about 3/4" wide. That's what I use and I build a lot of furniture.
Reply:http://www.harborfreight.com/cpi/cta...emnumber=92158
Reply:If this artwork is painted eye-candy, don't weld the inside corners...JB-Weld or Bondo and square file.  Just a thought....
Reply:By clean up what do you mean?Are we talking "looks like it was made from a single chunk of material" or just smoothing it out a bit?
Reply:Air file.
Reply:The piece will be powder coated. I tried to talk everyone involved in letting me get buy with painting the steel.....but no go.  The inside corners need to be really square to get the desired effect. I tried using the cutting disk idea and it is working very well. Its a bit touchy, but I have it figured out so its safe and very accurate (I don't remove too much metal).Thanks for all your suggestions. I'll post a couple of progress photos when I get things laid out.Timmer
Reply:Don't weld them. As long as there is no gap in the steel and the powder coater is aware that you don't want the crack to show it should be okay.
GMT+8, 2025-12-29 22:33 , Processed in 0.076816 second(s), 18 queries .
