for sale, Lincoln SA200, $900 in central FL
发表于 2021-8-31 22:44:26 | 显示全部楼层 |阅读模式
super good deal (my opinion only), found on craigslist. still available when I spoke to the guy on the phone about three hours ago. don't know the guy, never met him, and have no vested interest in the deal. wants $900 for (what looks to be a) nice Lincoln SA200 welder on the trailer, with leads...http://lakeland.craigslist.org/tls/734849230.htmllincoln welderthis is the info that's NOT in the post:welder has hand crank AND electric start, both working. "welds good AND runs good" per the seller. tires are new, seller says (though he recommends repack wheel bearings for a 2.5 hour tow). trailer it's attached to (goes with it and) requires a two inch ball. says he took the muffler off, and it needs a new muffler. unclear wether he still HAS the muffler or not. says it's been brush-repainted with (I assume gray) rustoleum (after these photos were taken, I guess, which means "very recently'). engine is a continetal, four cyl flathead. he 'thinks' vacuum-operated governorseller also says (I asked) the repaint is on the outside-facing skin surfaces only, not on the engine, inside the engine compartment, or on the inside of the side lids. per mickey, it has VERY little rust.let's assume, folks, that if the craigs site address above doesn't answer the welder HAS been sold. I know NO more about than is posted here, so no reason to ask me anything...I couldn't give you an answer to it anyway.guys name is mickey, he's in lakeland FLLast edited by dave_welder; 06-30-2008 at 04:22 PM.Reason: add a sentence
GMT+8, 2025-12-30 00:10 , Processed in 0.101357 second(s), 18 queries .
