Squat Rack (Gym Equipment)
发表于 2021-8-31 22:44:21 | 显示全部楼层 |阅读模式
Super simple build 2x2 square tube 11 gauge. Customer is happy! Note it is not "squared up" in the picture. I just slipped the bolts in for the picture and to make sure it "fit together". Attached ImagesDave ReberWadsworth Ohio
Reply:Looks good, going to have to build one for myself.
Reply:Thanks MadskillzI personaly have to work out in a gym. If I built a "home" gym I would not work as hard.Dave ReberWadsworth Ohio
Reply:Nice work.  What goes on it? Looks lighter than  squat racks I have seen?
Reply:TapwelderI'm not sure the max load. The one I copied this from (mine is stronger) is loaded to 500lbs often.Dave ReberWadsworth Ohio
Reply:Nice build! I had to read your post again....thought the bolts were permanent.Last edited by ScubaSteve; 10-23-2013 at 07:40 PM.Reason: Lack of attention!
Reply:Tap. having put together Many a squat rack (Used to work an a sporting goods store), that's just as strong or stronger as any I've touched.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Originally Posted by ReebsThanks MadskillzI personaly have to work out in a gym. If I built a "home" gym I would not work as hard.
Reply:Plus the hot sweaty women are easy on the eyes.Dave ReberWadsworth Ohio
GMT+8, 2025-12-29 22:31 , Processed in 0.073806 second(s), 18 queries .
