Rolled or welded?
发表于 2021-8-31 22:44:18 | 显示全部楼层 |阅读模式
Howdy,Seeking opinions, gentlemen.Customer sent me this weird handrail, which looks welded to me: the took 45 or whatever degree elbows and welded to straight runs, but was it bent by chance? Attached ImagesThermal Arc Fabricator 181IDayton 230/140 stickEvolution 14" dry sawafter  12 years of wood work, realized that the best wood working tool is a welder.
Reply:It could be either...Welding/Fab Pics: www.UtahWeld.com
Reply:Judging by the kinks near the bends, I'd say it's been bent. Any muffler fab shop can do that.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Could be either, but I would say bent.
Reply:It could be bent, but bear in mind that elbows are commonly used in pipe rail fabrication.In that picture though, the kinks look indicitive of a bender not suited for the job. Too much deformation in the bends. Either that or somebody does not know how to weld elbows in and make it look fluid.-Niche
Reply:I'm a decent tig hand by now, and an amateur bender. but welding grinding and polishing 12 ft of a rail like this sound a way more time consuming than bending it. Would you say time saving would justify buying one of these?http://www.trick-tools.com/Pro_Tools...FQdo7AodZTUAmAOr maybe I could get away with a basic hydraulic Harbor freight bender?Thermal Arc Fabricator 181IDayton 230/140 stickEvolution 14" dry sawafter  12 years of wood work, realized that the best wood working tool is a welder.
Reply:Thanks a bunch all y'all.Thermal Arc Fabricator 181IDayton 230/140 stickEvolution 14" dry sawafter  12 years of wood work, realized that the best wood working tool is a welder.
Reply:Originally Posted by NicheFabIn that picture though, the kinks look indicitive of a bender not suited for the job. Too much deformation in the bends. Either that or somebody does not know how to weld elbows in and make it look fluid.
Reply:Originally Posted by MikeGyverI don't see any kinking whatsoever. It looks CNC mandrel bent to me. It would be ridiculous to do it any other way if you had to make more than a couple of them.
GMT+8, 2025-12-30 00:00 , Processed in 0.100325 second(s), 18 queries .
