Safety Concerns on building a welding table
发表于 2021-8-31 22:44:17 | 显示全部楼层 |阅读模式
Just bought my first welder and wanted to start out by making a table for it, the gas, and all the other odds and ends that go with it.  What I'm worried about is putting the gas and the actual welder on the same table I plan to do the work on.  What are the safety issues regarding both the tanks and the welder itself being connected to the charged work surface?  Can I separate with wood or plastic?  (I would take precautions to avoid sparks coming in contact if that is the answer)  I really don't want multiple carts but I want my house exploding even less.  I appreciate your help on what I'm sure is a very novice question.Thank you-------------------------Miller Multimatic 200
Reply:You can put the gas with the welder.  It's inert gas, so it's not gonna blow up on you.  I would just make sure your bottle is sucure wherever you decide to put it.
Reply:Originally Posted by Murphy's lawYou can put the gas with the welder.  It's inert gas, so it's not gonna blow up on you.  I would just make sure your bottle is sucure wherever you decide to put it.
Reply:I would keep the tanks vertical.
Reply:Originally Posted by Murphy's lawI would keep the tanks vertical.
Reply:Why put it on the table when you can get a harbour freight cart for like 39 bucks w/coupons?
Reply:Originally Posted by Bosco99Why put it on the table when you can get a harbour freight cart for like 39 bucks w/coupons?
Reply:You'll find a welding machine confined to the table isn't the best setup for me at least. The machine will be fixed under the table which means, if you are using mig ,the cable and gun could have some tight bends in it which might not be the best for machine. The 10' gun cable is gonna get short real fast too. A separate cart setup for multiple machines or three shelves will make it extremely useful.
Reply:Originally Posted by smijwDepending on the feedback in this forum that was my next option
Reply:it should be okay from a safety standpoint but having a cart would save the table space and alow you to work away from the table
GMT+8, 2025-12-29 23:59 , Processed in 0.108956 second(s), 18 queries .
