Contents of unmarked Cylinder
发表于 2021-8-31 22:44:16 | 显示全部楼层 |阅读模式
I just picked up 9 cylinders from a HVAC company that went out of business, most have the contents labeled but one cylinder only has a partial label so I'm not sure whats in it. My guess is O2 or CO2, but one tank did have a Nitrogen label so that's also a possibility i guess.What is Nitrogen used for in the HVAC business - just curious?Can my LWS provider run some kind of test to determine the contents?Thanks,Mark"Never trust anything you read on the Internet" - Abraham Lincoln
Reply:nitrogen is used to purge the linesFYI oxygen will not have a cga 580 valvejust take it down and swap it outLast edited by WeldorWes; 07-17-2013 at 08:09 PM.Miller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Nitrogen can be used to run a plasma cutter or anything that you would normally use an air compressor for.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Nitrogen is used to test refrigeration piping and systems. Purge natural gas lines before welding on them .
Reply:MarkNotMarcMy favorite use of Nitrogen.Firing 1000 rounds at caliber/range distance to measure the surface deflection of AR 500.  To speed the trial: minimum three arms/ten round cycle - slow flow with N - to hand warmth.Repeat.Opus
Reply:Are all the cyls the same?HVAC uses nitrogen,CO2,oxygen and acetylene.......could be any of those.
Reply:You may already know that CO2 uses the CGA 320 style of threaded connection. It is by itself with a nut that goes over the threads on the cylinder outlet. It generally uses a plastic or fiber washer to seal the connection to a flow meter, although some flow meters have an o-ring built into the adapter. The other main type is the 580 style with the nut screwing into the cylinder valve. That could contain Argon, Argon/CO2 or any gas using that style of valve. I don't know all of the types. As others said above, it you have an unmarked cylinder and aren't sure, it would be safest to trade it in, or at least try to have your supplier identify it.Miller Millermatic 252Miller Syncrowave 200Liincoln AC-DC 225Victor O-A Set
Reply:Is the cylinder painted? O2 cylinders are almost always green, Any other color could be just about anything, I have seen CO2 cylinders in blue quite a bit used on air lifts (HVAC air powered duct lifts), they tend to have the safety guard built into the tank around the valve
Reply:Don't bet on the color of any cylinder.  Thoroughbred (http://www.gaspony.com/) paints ALL their cylinders blue - Acet, Oxy, CO2, Argon... except propane is white.   Airgas paints all their specialty gas cylinders teal.  From Airgas:  http://www.airgas.com/content/detail...=7000000000243  Right in the first paragraph you will find this tidbit of advice:  "Cylinder color should never be used to identify contents. Please read the contents label."If you can't ID the contents of any cylinder then take it to your LWS for inspection.- MondoLast edited by Mondo; 07-21-2013 at 08:39 AM.Reason: spelling correctionsMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
GMT+8, 2025-12-30 00:00 , Processed in 0.104749 second(s), 18 queries .
