found this pic
发表于 2021-8-31 22:44:12 | 显示全部楼层 |阅读模式
I  was on the http://garagejournal.com/forum/showthread.php?t=39003 site and found this pic.  I though it was pretty cool. hope everybody survived the 4th.there are more.
Reply:Don't wanna be there when it drops out!:A butterfly without wings, is just an ugly bug
Reply:I wouldn't have believed it if I hadn't seen it. Didn't know it was possible to cut steel that thick with a torch!Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:This page has more info about that pic and many more from a ship building co.  http://www.shipsnostalgia.com/guides...turing_Process
Reply:Originally Posted by gizzardgutzI wouldn't have believed it if I hadn't seen it. Didn't know it was possible to cut steel that thick with a torch!
Reply:Already postedLast edited by 59halfstep; 07-05-2009 at 03:44 PM.Charlie
Reply:that's cool .   what size tip   loldaye
Reply:Wow that is just a arm on a crankshaft!Serious engineLast edited by Atomik777; 07-05-2009 at 06:21 PM.Here learning to turn down the Suck...
Reply:Originally Posted by Stone_ElvisI  was on the http://garagejournal.com/forum/showthread.php?t=39003 site and found this pic.  I though it was pretty cool. hope everybody survived the 4th.there are more.
Reply:Originally Posted by fortyonethirtyThis page has more info about that pic and many more from a ship building co.  http://www.shipsnostalgia.com/guides...turing_Process
Reply:I'm glad I don't have to buy the oxygen for that cut!!!! Thanks for the pic.                         MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:The engines much larger now and they use plasma to cut the crank arms.  That's a built up crank.  The main bearing journal and crank pin are interference fit only, no welding in the construction of the crank.  I think Sulzer/Wartsilla still builds their engines like that.  Man B&W uses a weld up type construction where the crank is built up out of forged sections that include 1/2 the main bearing journal, the crank web, and 1/2 of the crank pin.  Just think of the process involved in welding together an 18 inch diameter shaft.
Reply:"Don't need no stinkin' glasses when I'm cutting this tin, I send the sparks under the cut." Nice post!
Reply:No ear protection. Imagine how loud that is?Lincoln Ranger 8                        Lincoln 175                          Drill pressLincoln 225 mig                            Plasma                              8 ft brake        52" jump shear
Reply:You could probably skip the steel toed boots however. If that drops on your foot, you'd need to be wearing a tank to have any chance.
Reply:The scale of everything is unimaginable!  And not a hard hat or safety glasses in sight!It's not what you can buy, it's what you can build.
Reply:That thing had to be hot for weeks after the cut was completed!
Reply:If you look closely you can see that this is an opposed piston engine, vertical.  The doxford had rods running vertically up each side of the cylinder connected to cranks that were 180 degrees from the lower piston crank.  This was a solution to avoid cylinder head problems.  The scavenging of gases was all in one direction also but it was a nightmare of linkages.  Two pistons facing each other created the ideal spherical combustion chamber.  The magnetic tracer on the table following the template really dates this photo.
Reply:During the Second World War they had pantograph type milling machines.  Able to do trace a stock part and re create it.  All manual mechincal stuff"Any day above ground is a good day"http://www.farmersamm.com/
Reply:RE the torch pic, the hat dates it too"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammRE the torch pic, the hat dates it too
Reply:"Any day above ground is a good day"http://www.farmersamm.com/
Reply:dang some nice pics some times i think i missed out on the good years lol but then i now have my autocad and solidworks and am happy to build the part on the computer first before i build it in my shopMillermatic 252Miller 675 plasmaJet bandsawchampion 80 gal. air compresservictor oxy-act torch
GMT+8, 2025-12-30 00:02 , Processed in 0.096477 second(s), 18 queries .
