Plasma Air Filter Mounting Bracket
发表于 2021-8-31 22:44:12 | 显示全部楼层 |阅读模式
Not too special here, but it might provide food for thought if you ever run into trying to mount  something with pipe that simply has no good mounting points and you need something solid.  This is a Motor Guard Filter for my plasma cutter.  It's a simple mount, a piece of angle welded to 1/2 black iron pipe, a couple of holes for lags and complete.  Solid as a rock.
Reply:Simple, and effective! City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
GMT+8, 2025-12-30 00:11 , Processed in 0.094052 second(s), 18 queries .
